What is at the Edge of a Closed Universe?
  • Thread starter Thread starter Monoxide
    Closed Universe
The discussion centers on the concept of a closed universe and its implications for understanding the universe's edge. It is clarified that a closed universe, while theoretically allowing for a return to the starting point after traveling in one direction, does not align with current evidence suggesting a flat, accelerating universe. The expansion of the universe means that even if one could travel at light speed, they would never reach an edge. Olbers' paradox is referenced to explain why the night sky is dark, attributing this to the universe's expansion and finite age. Ultimately, the conversation highlights the complexities of cosmology and the limitations of our observational capabilities regarding distant galaxies.
Monoxide
Hello, first post here, I hope someone can help me with this.
While not having studied physics myself, I am reasonably familiar with many key topics, in this case I found myself thinking about the standard Big Bang model.
The question is simple - 'What is at the edge of the Universe'.
My understanding was that spacetime was curved such that the universe was 'closed' The result was that the universe had no edge and that if one traveled in one direction long enough, one would return to ones starting point.
This, I realized, can not be true though because such a universe would effectively be infinite (like being in a mirrored elavator) which would result in the Earths sky being as bright as the Sun from horizon to horizon as stated under Olbers paradox.
My gut feeling is that my understanding of what a closed universe is is flawed, but if not - what is at the edge of the universe?
Thanks in advance
Space news on Phys.org
Oh wait...
Is it because the light wouldn't have had time to reach us yet from stars viewed in the 'mirror universes'? I think I have answered my own question! Comments still welcome!
:rolleyes:
Most or less correct Monoxide, and Welcome to these Forums!
Olbers Paradox says that if the universe were
1. Infinite,
2. Eternal (infinitely old) and,
3. Static
then the sky at night should be burning bright.
The fact that it is expanding will dilute the radiation so that it is not bright but dark at night as observed, also it is (probably) not eternal, so there has not been enough time to circumnavigate the universe.
Finally, as the universe is expanding, light will never be able to complete the circumnavigation it in the first place.
The end result? The sky is dark at night!
Garth
But what of this issue of the edge of the Universe - is the closed universe idea I mentioned valid (that by going straight in one direction onwe ends up at the starting point)?
Or is it a moot point as expansion means that we would never reach the edge even if we set off at light speed?
I tried explaining BB to a friend who immediately asked what is beyond the edge - a reasonable question that I struggle to find a reasonable answer to.
No. So far, the evidence points to a flat, accelerating universe.
Yes.
The farther we look, the greater the redshift. Hubble Constant*Distance=Recession Velocity. The value of "Distance" is the distance from the original state (the big bang singularity). Since no location can necessarily claim to be the center of the universe (Cosmological Principle), it is ok to pick any location as the center point. Two things affect how far we can see. First is the Recession Velocity. Where recession velocity equals c, objects are redshifted so much that we cannot see them any more. The equation for redshift as a function of recession velocity (in special relavitity) is this:
z=sqrt[(c+v)/(c-v)]-1
While v<<c, the value of z is finite
http://www.google.com/search?q=c/((71+km/s)/Mpc)+in+light+years
1.37720275 × 10^10 light years
The rate of expansion of the space-time continuum can exceed the speed of light.
The second thing that affects how far we can see the brightness of the light of the era of the universe we are looking at. So far, we can image individual galaxies and their structure at a distance exceeding 13 billion light years. However, we cannot image clearly individual stars of those distant galaxies. Also, Hubble's instrumentation does not detect ultra high redshifts at sharp enough resolution to image the first stars. The resulting demand is the Next Generation Space Telescope (NGST), or James Webb Space Telescope (JWST) which will have a resolution higher than Hubble at the infrared range.
If you look at the light from the very distant galaxies at the same position you are right now, there would be no way of seeing these galaxies as they are right now, because all of these galaxies have already rushed beyond the edge of the universe. Their comoving distance is greater than 1.37720275 × 10^10 light years. One by one, the entirety of a galaxy passes a region where it is 1.37720275 × 10^10 light years from us. 1.37720275 × 10^10 light years after a galaxy or star goes beyond that we cannot see it or reach it any more.
https://en.wikipedia.org/wiki/Recombination_(cosmology) Was a matter density right after the decoupling low enough to consider the vacuum as the actual vacuum, and not the medium through which the light propagates with the speed lower than ##({\epsilon_0\mu_0})^{-1/2}##? I'm asking this in context of the calculation of the observable universe radius, where the time integral of the inverse of the scale factor is multiplied by the constant speed of light ##c##.
The formal paper is here. The Rutgers University news has published a story about an image being closely examined at their New Brunswick campus. Here is an excerpt: Computer modeling of the gravitational lens by Keeton and Eid showed that the four visible foreground galaxies causing the gravitational bending couldn’t explain the details of the five-image pattern. Only with the addition of a large, invisible mass, in this case, a dark matter halo, could the model match the observations...
Hi, I’m pretty new to cosmology and I’m trying to get my head around the Big Bang and the potential infinite extent of the universe as a whole. There’s lots of misleading info out there but this forum and a few others have helped me and I just wanted to check I have the right idea. The Big Bang was the creation of space and time. At this instant t=0 space was infinite in size but the scale factor was zero. I’m picturing it (hopefully correctly) like an excel spreadsheet with infinite...
