Charged particle near a grounded plane
The problem involves a point charge q of mass m released at a distance d from an infinite grounded conducting plane, with the goal of determining the time it takes for the charge to hit the plane. The context is rooted in electrostatics and dynamics, as described in Griffiths' text.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • Participants discuss the forces acting on the charge and set up differential equations to describe its motion. There are attempts to manipulate the equations using substitutions and integrations to find a solution for time t.
Several participants have offered insights and suggestions for substitutions and manipulations of the equations. There is an ongoing exploration of different methods to solve the integral involved, with some participants expressing uncertainty about their approaches.
Participants mention specific substitutions and manipulations, such as using y = ln x and x = d sin²(θ), indicating a variety of strategies being considered. There is also a note of frustration from one participant regarding the lack of replies, suggesting a need for further engagement in the discussion.
Reshma
This one is from Griffiths. A toughie!
A point charge q of mass m is released at a distance d from an infinite grounded conducting plane. How long will it take for the charge to hit the plane?
I chose a distance 'x' as a height above the plane. So the force on 'q' is given by:
[tex]F = {-1\over 4\pi \epsilon_0}{q^2\over 4x^2}[/tex]
And equal that to force equation:
[tex]F = m\frac{d^2 x}{d t^2}[/tex]
So,
[tex]\frac{d^2 x}{d t^2} = \frac{-q^2}{16\pi \epsilon_0 x^2 m}[/tex]
I need to solve this equation for 't'. Any clues?
Oh, by the way, for once Griffiths has been kind enough to provide the solution for this problem :biggrin:.
[tex]t = \left({\pi d \over q}\right) \sqrt{2\pi \epsilon_0 md}[/tex]
This should be helpful.
So,
You will find the substitution y=ln x useful.
-Dan
You can multiply both sides by 2 dx/dt. This will leave you with d/dt((dx/dt)2) on the left side and d/dt(something else) on the right side, which you can easily integrate to get a first order ODE.
-Dan
Did not work :frown: .
OK, I multiplied it by v = dx/dt on both sides.
[tex]v {dv\over dt} = \left({q^2\over 16\pi \epsilon_0 m}\right)\left({-1\over x^2}\right){dx\over dt}[/tex]
Taking [itex]A = {q^2\over 16\pi \epsilon_0 m}[/itex]
[tex]{d\over dt}\left({1\over 2} v^2\right) = {d\over dt}\left({A\over x}\right)[/tex]
So,
[tex]{1\over 2} v^2 = {A\over x} + \mbox{constant}[/tex]
I need to bring this 'v' in terms of 'x' to integrate. How do I proceed?
Oh dear, no replies...:rolleyes: .
I proceeded with evalutions and I think I figured out the answer.
When v = 0; x = d. So, constant = (A/d)
Hence,
[tex]v^2 = 2A\left({1\over x} - {1\over d}\right)[/tex]
[tex]{dx\over dt} = \sqrt{{2A\over d}}\sqrt{{d-x\over x}}[/tex]
[tex]\int_0^d {\sqrt{x}\over \sqrt{d-x}}dx = \sqrt{{2A\over d}}t[/tex]
I just need to solve this for 't' but I'm not able to find a suitable substitution for the integrand terms to evaluate them. Any CLUES?
put d-x = t square . u will get integeral of the form integeral(dt/(d-t^2)^1/2) which is a standard integeral . i don't know there might be a shorter way ... but u ll get the answer through this
Hi Reshma,
You are on the right track. Along the lines gandharva suggested, you might try a substitution of the form [tex]x = d \sin^2{\theta}[/tex].
Thanks, Physics Monkey and gandharva. I got the answer.
  • · Replies 19 ·
