Why Does the NO Switch Not Maintain Closure in a Seal Circuit Simulation?
  • Thread starter Thread starter muganga
    Circuit
The discussion centers on troubleshooting a seal circuit simulation involving a normally open (NO) switch, normally closed (NC) switch, and a contactor to start a motor. The user, Fernando Azevedo, reports that the NO switch does not maintain closure when activated. Participants inquire about the simulation software being used and suggest checking circuit design references. The conversation highlights the need for proper configuration to ensure the NO switch functions correctly in the simulation. Effective troubleshooting and circuit design are crucial for successful motor operation in this context.
muganga
hello everybody...i need help about how simulate a seal's circuit (contactor + 1 switch NO + 1 switch NC). My circuit is to start a motor...i traied simulate but when i push NO..it didnt keep close.
thanks so much...if you can add at MSN to exchange information about EWB i'll thanks a lot.
Fernando Azevedo
mugangalinux@hotmail.com
Brazil
"i traied simulate but when i push NO..it didnt keep close."
What are you simulating this with?
Fernando Azevedo
Brazil
Does your circuit look something like http://www.sea.siemens.com/step/templates/lesson.mason?components:3:2:8" ?
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
11K
