Explaining Resistance in pH of Buffer: Strong vs Weak Acids
The Henderson-Hasselbalch equation can technically apply to strong acids, but it is not suitable for calculating pH in the same manner as for weak acids. Strong acids exhibit slight pH changes even with significant neutralization due to their high dissociation, while weak acids maintain pH stability because they dissociate minimally. Buffer capacity is primarily attributed to weak acids, as they can maintain a relatively constant pH by adjusting the concentrations of their conjugate base and acid. Strong acids are not typically used for standard buffer preparation, as their behavior does not align with the principles of buffering. The discussion highlights the fundamental differences in pH resistance between strong and weak acid buffers.
Samurai33
could the equation - pH=pKa+log([A]/[HA]) - be applied for the case of strong acid? Although the percentage of dissociation of strong acid/base is very high, there still exists a equilibrium, right?
secondly, if i tried to explain the resistance in pH of buffer *in terms of* the above equation, then the pH of a buffer will depend only on the ratio of [A]/[HA]; then for both strong/weak acid with its salt, if i add H+ to each solution, the result will be: [A] decrease; [HA] increase (both cases). then how can i explain the difference that weak acid buffer has the ability to resist change in pH?
Please help me to solve this query, thanks a lot!
First question - Henderson-Hasselbalch equation works for strong acids too, although it can't be used for pH calculation, at least not in the same way as in the case of weak acids.
Second question is in fact about buffer capacity. Strong acids resist pH changes as well, although in slightly different way. In the case of strong acid pH changes only slightly in the case of relatively concentrated solutions, as neutralizing even 10% of acid doesn't change pH much. In the case of weak acids pH changes only slightly because weak acids are in a way inert - they almost don't dissociate on their own. Thus concentration of A- and HA can be easily forced on the solution, and as long as they don't change much, pH doesn't change as well.
To be more specific, it cannot be used for calculating pH of buffer with strong acid and its salt??
See the page mentioned (part about dichloroacetic acid).
You don't need to use the H-H equation, also, strong acids/bases are not employed for making standard buffers.
GCT said:
Ystrong acids/bases are not employed for making standard buffers.
How are you going to prepare pH = 1 buffer solution?
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
