2 point charges with sphere inbetween
Cairrd
I am having a little trouble knowing how to approach the following question:
Twi point charges q and -q are placed 2d apart. Show that a conducting sphere of small radius r (where r << 2d) is placed midway between the charges, show the force on each is increased by a factor of approx (1 + 16 (r^3/a^3)).
Anyone want to help me here?
Thanks
Use the method of images on the conducting sphere, and then treat the two images as a dipole when you calculate the total force on one charge due to the other charge and the image charges.
Also, I assume you mean d, not a, in your factor.
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
