Build a Mouse Trap Car: Backwards Motion Help
  • Thread starter Thread starter Kerri23
    Car
To build a mouse trap car that can move 2 meters forward, pick up an object, and then reverse 2 meters without manual intervention, the design needs to focus on effective propulsion in both directions. The current setup uses a string attached to the axle, which unwinds to propel the car forward but lacks a mechanism for reverse motion. Suggestions include rethinking the mechanical components to allow for dual propulsion, potentially using Velcro to secure the object instead of relying on a separate mechanism. Exploring innovative solutions that adhere to the project’s constraints can enhance functionality. Creative problem-solving is essential for achieving the desired movement in both directions.
Kerri23
I am suppose to build a mouse trap car ...it must go 2m forward, pick up an object and go 2m backwards without me touching it. i can get it to go forwards and pick up the object but not backwards. my design is fairly simple..there's a string attached to the axle.. the other end is attached to the part that comes down on the mouse. you pull that part back and wind up the string by turning the axle back. when the part that hits the mouse springs forward, it unravels the string and spins the wheels. but i have no idea how to make it go backwards. ( it goes backwards if you wind it up the other way though)
any hot ideas would be appreciated.
-note: i can only use one mouse trap
Welcome to PF, Kerri.
Have you considered devoting all of the mechanical bits to forward and backward propulsion, and simply Velcroing the 'mouse' and the front of your vehicle?
Keep in mind here that I think farther outside of the box than most. Rules can't be broken, but I like to bend them into the form of singularities. :biggrin:
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
