How Do You Calculate the Frequency for a 90 Degree Phase Shift in Coils?
The discussion centers on calculating the frequency for a 90-degree phase shift between two coils in series. An experiment revealed a phase shift at approximately 9 MHz, despite theoretical expectations of minimal phase differences due to identical coils. The phase shift may occur if one coil's self-resonance frequency is significantly lower than the applied frequency, while the other's is much higher. To calculate the frequency for a specific phase shift, one must measure the inductance, parasitic capacitance, and series resistance of the coils, then analyze their complex impedances. Resources for understanding AC theory and relevant calculations were also shared.
Jdo300
Hello All,
I did an experiment recently involving two coils in series with a high frequency signal running through them. My goal was to determine at what frequency the signal in one coil would be phase shifted by 90 degrees with respect to the first coil. I was able to experimentally determine the right frequency but I am wondering how one would calculate the frequency that would give you a 90 degree phase shift in voltage knowing the inductance of the coil.
Thanks,
Jason O
That's weird. Theoretically you shouldn't have a phase shift between the two coils. Even if we consider the series resistances of the coils, there could only be a very small phase shift between the signals measured at the terminals of the two coils. This very small phase shift would exist if the phases of the complex impedances of the two coils (each modeled as an inductance in series with a resistance) would differ.
Anyway, what was the frequency that you measured?
Hi,
I think the reason I got the phase shift is because I was driving the coils close to their natural resonant frequency. I got the 90 degree shift when I drove the coils at about 9 MHz. They are not very large coils either, only about 50 turns each around a styrofoam core that is about 1.5 inches in diameter.
From what you sad I understood that the two coils are identical, right? This means that no matter what frequency you apply the phase shift should be (close to) zero.
You might get a phase shift of 90 degrees if you choose the two coils so as the self-resonance frequency of one of them is much below the applied frequency and the self-resonance frequency of the second is much above the applied frequency.
Now, back to your question, you can calculate the frequency that will give you a phase shift of n degrees, but you must measure the inductances, the parasitic capacitances and the series resistances of the coils. Then, you calculate the complex impedance of each coil (X_{L}+R)||X_{C} and see at what frequency the phase shift between the two impedances is n degrees.
Ahh thanks for the clarification. I haven't learned those equations (using complex numbers) yet. Could you give me a general example that I can use once I determine the Inductance and capacitance of my coils?
Thanks,
Jason O
Thanks,
Jason O
There's no point in using formulas that you don't understand. Here is a good website which covers AC theory from scratch, and has very practical explanations: http://www.ibiblio.org/obp/electricCircuits/AC/index.html
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
