Solving Matter & Antimatter Problems: Need Help Getting Started?
  • Thread starter Thread starter kingwinner
    Antimatter Matter
The discussion revolves around a problem involving the collision of two plasmas in space, one containing protons and electrons and the other containing anti-protons and positrons. Participants are exploring the expected spectral signatures resulting from potential annihilation events and the conditions under which these occur.
  • Participants are attempting to understand the conditions for annihilation between particles and the implications for spectral signatures. Questions include the completeness of annihilation, the role of mass and velocity in calculations, and the number of photons produced in the process.
The discussion is active, with various interpretations being explored regarding the annihilation process and the resulting energy calculations. Some participants have offered insights into the relationship between mass, energy, and photon production, while others are questioning the assumptions about particle interactions and the definition of rest wavelengths.
Participants express uncertainty about the mass and velocity of the plasmas, which complicates their calculations. There is also a discussion about the meaning of "rest wavelength" and its implications for the problem at hand.
kingwinner
I am really stuck on setting up the problem & equations to solve, can someone please help me out with this beginning step?
The question is:
1) A plasma out in space containing protons and electrons meets up with another plasma containing anti-protons and positrons. At what rest wavelengths would you expect to observe the spectral signatures of this collision?
Will both plasmas annihilate completely or only half of each plasma will annihilate? I know that when protons and antiprotons collide, they annihilate completely. But in this case, say, the protons surely can collide with the positrons instead of colliding with the anti-protons, right?
I think I need the "mass" to do the calculations. How can I figure out the total mass the the two plasmas? I don't know how many protons, positrons, etc., there are...
And I don't even know the speed of the protons, positrons, etc., how can I calculate the energy without the speed of the particles?
How many photons will be released? One? Two? Three? How can I know?
Any help of any kind is greatly appreciated! Thank you!:)
A proton and antiproton will annihilate each other. Same with an electron and a positron. Each of these will result in its own set of photons with specific wavelengths. More matter will just result in more photons with the same wavelengths.
as far as i know protons shouldn't anihilate the positrons. whilst they have opposite charges they are not the matter/antimatter reflections of each other
i think
Should would the 2 plasmas annihilate completely?
Another trouble is that I don't know the mass and velocity of the plasmas...
Can anyone explain in greater detail? Thanks!
But another trouble is that I don't know the mass and velocity of the plasmas...
The problem says "at what REST wavelengths". While not very good english, I assume this would mean you can ignore the velocities. The total mass, whether annihilation is complete etc etc are irrelevant. Just take eg one e+/e- encounter. What happens?
But the protons, antiprotons, etc., have kinetic energy before they collide, if I am not given their velocities, how can I find the total energy (the quantity that is conserved)?
So we only need the mass of the protons, antiprotons, electron, and positron rather than the mass of the plasmas in doing this calculation?
Yes. I think you can assume the KE is negligible compared with the annihilation energy. And, yes, the mass of the plasma would only affect the intensity and amount of radiation. Not the spectrum.
So
E=2mc^2=hc/(wavelength)
wvaelength=h/(2mc)
Substituting mass of proton and I get the first wavelength?
Substituing mass of electron and I get the second wavelength?
Am I right?
By the way, what is the meaning of REST wavelength? At rest relative to what (in which frame of reference?) ?
Thanks for your help!
I'm assuming 'rest wavelength' means the the annihilation is at rest relative to the observer. And yes, you are almost right. But does it seem ok that two particles can annihilate and produce a single photon and still conserve momentum?
So I guess there will be 2 photons, giving the following calculations:
E_final=2(E_photon)=2mc^2=E_initial (Conserivation of energy)
And 2*hc/(wavelength)=2(E_photon)=2mc^2
So wavelength=h/(mc)
But why 2 photons? not 3 or 4 photons?
Excellent question! I don't think 3 would workkinematically, though I could be wrong. 4 would. But this would be a rare process (it would involve more loops in a Feynman diagram - are you working at this level or is it just a simple question?).
One could also note that the annihilation in general can be a messy process. e+/e- is pretty clean but p+/p- is not. There could be other products. But I don't think that is what the question is after.
Just wondering...but nevermind...I don't think I am up to that level
So in most cases, 2 photons will be produced when 1 particle and 1 antiparticle collide?
Likely there are other ways for protons to annihilate - but you probably don't care much about them since their products are unstable and more than a two body decay won't give you sharp spectral lines.
13K
  • · Replies 21 ·
  • · Replies 21 ·
