Please correct this excercise
  • Thread starter Thread starter championnn
To find the average rate of change of the function F(x) = x - 2x^2 from x=1 to x=2, the correct formula is (F(2) - F(1)) / (2 - 1). The calculation involves determining F(1) and F(2) first, which are F(1) = -1 and F(2) = -6, leading to an average rate of change of (-6 - (-1)) / (2 - 1) = -5. The original calculation presented was unclear and incorrect in format, lacking proper expression of the average rate of change. Clear step-by-step writing is encouraged for better understanding and communication.
championnn
they ask me to find the average rate of change from x=1 to x=2 in the equation x-2x^2
this is what I did
2-2(1)^2/2-1 = 0/1= 0
is that right?
thanks
It is difficult to tell just what you did.
Average rate of change would be something like:
\frac {F(x_1) - F(x_2)} { x_1 -x_2}
Your F(x) :
F(x) = x - 2x^2
Keep in mind, that x is common in that expression, the first x must equal the 2nd x.
this is what I did
is that right?
thanks
What you wrote, even if the calculations are correct, is meaningless.
First, I suspect you MEAN (2- 2(1)^2)/2- 1, not what you wrote.
In any case, you need to write "the average rate of change is ... " so someone reading this will know what you are doing.
What is the value of the function when x= 1?
What is the value of the function when x= 2?
What is the change in the value?
What is the average rate of change?
It strongly urge you to get into the habit of writing your work one step at a time like that. It will make it clearer to others what you are doing and, hopefully, make more sense to you (and probably give your teacher a heart attack!).
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
