Stiochemistry practice problems help
  • Thread starter Thread starter LraeByrne
    Practice problems
To determine the moles of aluminum needed to form 3.4 moles of aluminum oxide, the balanced equation 4Al + 3O2 → 2Al2O3 indicates that 4 moles of aluminum produce 2 moles of aluminum oxide. This establishes a ratio of 4 moles of Al to 2 moles of Al2O3, simplifying to 2 moles of Al for every mole of Al2O3. To find the required moles of aluminum (x) for 3.4 moles of aluminum oxide, the equation can be set up as x/3.4 = 2/1. Understanding this ratio is crucial for solving the problem effectively. Mastery of balanced reaction equations is essential for tackling similar stoichiometry problems.
LraeByrne
Aluminum oxide is formed from the reaction of metallic aluminum with oxygen gas. How many moles of Aluminum are needed to form 3.4 moles of Aluminum oxide?
first equation:Al + O2 --> Al2O3 i balanced it at 4Al + 3O2 --> 2Al2O3
okay I just really need help understanding this because I have no clue what I am doing and don't understand how to work the problem! please help:confused:
Ok, so you've balanced your equation correctly. From this you know that 4 moles of aluminium produce 2 moles of aluminium oxide, and want to calculate the number of moles of Al required to produce 3.4 moles of aluminium oxide (x, say).
1. What is the ratio of Al to Al2O3?
2. Can you set up a ratio equation for x?
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
