Understanding the Master & Slave Roles in IIC Bus Technology
In IIC Bus technology, the master is the controller that manages communication and dictates when data is transmitted, while slaves are the devices that respond to the master's commands. Each slave has a unique address that the master uses to communicate, ensuring that only the addressed slave responds to a command. The master sends a slave address immediately after a START signal, and only the slave with the matching address acknowledges the communication. In scenarios with multiple masters, arbitration occurs to determine which master controls the bus at any given time. Understanding these roles is crucial for grasping how data is transferred effectively on the IIC Bus.
seang
Hey all;
I have to write a report on a certain bus (the bus is associated with a uC), based on a technical document. Thing is, we haven't learned much about buses yet. I understand most of it, but there's one thing I don't understand.
What is a slave and what is a master? Here's some phrases from the doc. I think If someone could explain them I'd have a lot better handle on buses and the master/slave idea in general.
"This register contains the address the IIC Bus will respond to when addressed as a slave."
"This would ultimately result in either the current bus master or the IIC Bus module losing arbitration..."
(the IIC is the name of the bus)
"IAAS — Addressed as a slave bit"
"0 = Slave receive, master writing to slave
1 = Slave transmit, master reading from slave"
"The first byte of data transfer immediately after the START signal is the slave address transmitted by the master."
"Only the slave with a calling address that matches the one transmitted by the master will respond by sending back an acknowledge bit."
Thanks.
The bus is just the medium for transferring data between units. The Bus type defines the architecture and the signal types that can be used on the data wires.
Master Slave Buses use a single Bus Controller (The Master) to control what and when information is transmitted on the bus. this prevents two units talking at the same time (Data Collision).
The Bus Controller will talk to every slave unit on the bus, but only the one which matches the address in the message header will respond to the command. The Bus controller will then wait to receive the response before sending out the next command. Generally Slave units cannot transmit unless directly commanded by the Master.
The slave stores a unique address which the Master can use to talk to it. Depending on Bus type this address can be fixed or dynamic and the master can either be preprogrammed with slave addresses or request an address.
I assume this is where you have the possiblility of multiple Bus Masters on a single Bus. A single Bus Master will controll all other devices as slaves, but under certain circumstances another Bus Master may take control of the Bus. The Bus Master is arbitrating between units to determine which unit communicates.
This is referring to information within the message header for a serial bus or on a specific line for a parallel bus to indicate which direction data is flowing in.
If this is in a dynamically addressed system the Master is telling slaves what addresses it wants to operate on and also finding out how many slaves are on the network. Otherwise it is referring to the fact that each message frame header begins with a start of message pattern and is then followed by the address of the slave unit the message is for.
Any other slave unit will hear the message but as the address will not match it's own it will ignore the instruction.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
