Do Magnetic Fields Exist in All Frames of Reference?
  • Thread starter Thread starter Swapnil
The discussion centers on the physical existence of electric (E) and magnetic (B) fields in different frames of reference, particularly in the context of relativity. It presents a thought experiment involving two observers, A and B, where the perception of magnetic fields differs based on their relative motion. While observer A sees no magnetic field due to a stationary charge, observer B perceives a magnetic field because the charge is moving relative to him. Most physicists resolve this by stating that the combined effects of E and B fields, along with relativistic effects like length contraction and time dilation, yield consistent results without a paradox. Ultimately, the conversation suggests that while E and B fields may be observer-dependent, their effects are real and significant in practical applications.
Swapnil
I was thinking asbout the physical existence of E and B fields. I would assume that most devoted physicists would say that they are as real as the chairs we sit on (I forgot the exact quote and the person who said it). But doesn't relativity disprove this fact? For example, consider the following thought experiment:
Say there are two observers A and B. Say observer A is on a train which is moving at some speed relative to observer B who is outside on the ground watching observer A pass by. Now, say there is positive charge infront of observer A. Accorrding to observer A there would be no magnetic fields emanating from the charge since the charge is stationary in his frame. However, according to observer B there would magnetic fields emanating from the charge because there charge is moving according to him.
Most physicists would resolve this apparent paradox by saying that the combination of E-fields, M-fields, length contraction, time delation etc would make it such that the net effect of that charge on its surroundings would be the same and hence there is no paradox.
However, doesn't this imply that magnetic fields are not real (since one person "sees" it the the other doesn't). And only their combined effect(i.e. forces) are real?
That's why relativistically, the electromagnetic field is really one thing. It's mathematically represented as a rank-2 antisymmetric tensor field (think 4x4 antisymmetric matrix). The standard electric and mangetic fields may be derived from this, but they are observer-dependent. I don't think this diminishes their physical "reality" at all (as much as that means anything).
If I'm in an airplane over Manhattan, and my son is waiting for a train in Penn Station, then we see quite different views. But they are both views of Manhattan.
B and E are real in the sense that they do real things -- move charges, carry TV images, make the hair on your head stand up,... when you examine the end result of whatever you do with E and B, your confusion should be eased.
Regards,
Reilly Atkinson
Special Relativity may explain why the magnetic force is a relativistic effect caused by relative motion of negative and positive charges. Your question seems to assume that the electric field is more "real" than the magnetic field. While the concept of "field" is a useful mathematical model that we can use to predict results, we should not get hung up on whether any field is "real".
The concept of the "field" was invented because we had a conceptual difficulty with Newton's "action at a distance". It is a successful model that gives us consistent results that fit with all known observation. Whether there is anything "there" or not does not matter to the scientist, and may be unknowable.
AM
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'A scenario of non-uniform circular motion'
(All the needed diagrams are posted below) My friend came up with the following scenario. Imagine a fixed point and a perfectly rigid rod of a certain length extending radially outwards from this fixed point(it is attached to the fixed point). To the free end of the fixed rod, an object is present and it is capable of changing it's speed(by thruster say or any convenient method. And ignore any resistance). It starts with a certain speed but say it's speed continuously increases as it goes...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
