Solving 6th Roots of Unity Problems
  • Thread starter Thread starter bosox097
    Roots Unity
The sum of the 6th roots of unity is zero due to their symmetrical distribution around the unit circle in the complex plane. The product of the 6th roots of unity is -1, as it can be derived from the properties of complex conjugates and their magnitudes. The discussion emphasizes the importance of symmetric functions and group theory in solving these problems. Additionally, it highlights the relationship between the roots and the vertices of a regular hexagon. Understanding these concepts aids in solving similar problems involving roots of unity.
bosox097
How do you do these two problems?
1. Find the sum of the 6th roots of unity.
2. Find the product of the 6th roots of unity.
Mathematics news on Phys.org
The real 2nth roots of unity, for any natural n, are -1 and 1. If a complex number is an mth root of unity (for any m) then its complex conjugate is as well. If z \in \mathbb{C} then z\overline{z} = |z|^2. Thus the product of the 2nth roots of unity (for any n) is -1.
Furthermore, -z is a 2nth root of unity whenever z is. Thus the sum of the 2nth roots of unity (for any n) is 0.
I hope this wasn't a homework problem! :rolleyes:
You should look at symetric functions. Take the cubic: (x-a)(x-b)(x-c)=0. Then if this is multiplied out, we get
X^3-X^2(a+b+c)+X(ab+ac+bc)-(abc) = 0.
look at the vertices of a regular hexgon and think of vector addition, and then use group theory.
(x-a)(x-b)= x2- (a+ b)x+ ab
(x-a)(x-b)(x-c)= x3- (a+ b+ c)x2+ (ab+bc+ ac)x- abc
(x-a)(x-b)(x-c)(x-d)= x4- (a+ b+ c+ d)x3+ (ab+ac+ ad+ bc+ bd+ cd)x2- (abc+ acd+ bcd)x+ abcd
Do you see the pattern?
Even more simply: the nth roots of unity are equally spaced around the unit circle in the complex plane. What does symmetry tell you about their sum?
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
