Magnetic force is a function of position?
Magnetic forces are influenced by position, time, and the velocity of charged particles, as outlined by the Lorentz force equation (F = qv x B). The magnetic field generated by currents varies with position and can also change over time if the currents fluctuate. While forces in classical physics typically depend on position, magnetic forces uniquely incorporate velocity as a critical factor. This means that magnetic forces cannot be expressed solely as a function of position without considering other variables. Understanding these relationships is essential for grasping the nature of magnetic forces in both classical and quantum contexts.
neelakash
Sir,can you tell me if magnetic forces are function of
position?Possibly,I read it somewhere in internet forums that magnetic
forces are functions of velocity.I have read in your QM book's first
page that---in microscopic level all type of force may be written as
-∂V/∂x...except magnetic forces.
Normally,forces are functions of position,velocity and time...I want
to know if the magnetic forces can be represented as function of
position only.I mean can we have a magnetic force depending on only
(x,y,z) and NOT their higher derivatives as well?
Please let me know.Your help will be greatly appreciated
Please refer to the Biot-Savart Law.
In addition, please do not start your post with "Sir". We have many women on this forum who are either physicists, or interested in physics, who could have answered your question.
Zz.
The magnetic field produced by a configuration of currents depends on position. It also depends on time if the currents vary with time.
The magnetic force that this field produces on a moving charge or current element therefore depends on position and time as described above, and on the velocity (b0th magnitude and direction) of the moving charge, or magnitude and direction of the current element.
That's strange, you are asking about classical physics (ie the Lorentz force) yet you have been reading in a QM book ?
Your answer is this : the force exerted by a mangetic field B on a charged (q) particle is called the Lorentz force F = qv x B. The x means vector product ! Both velocity v (of the charged particle) and B depend on coordinates t (time), x,y and z, by definition. The force F therefore indeed depends on spatial coordinates and time t.
marlon
I was using the Smith chart to determine the input impedance of a transmission line that has a reflection from the load. One can do this if one knows the characteristic impedance Zo, the degree of mismatch of the load ZL and the length of the transmission line in wavelengths. However, my question is: Consider the input impedance of a wave which appears back at the source after reflection from the load and has traveled for some fraction of a wavelength. The impedance of this wave as it...
