Nonconservative lagrangian systems
  • Context: Graduate
  • Thread starter Thread starter jdstokes
    Lagrangian Systems
The discussion revolves around the conditions under which velocity-dependent forces can be derived from a Lagrangian framework in Lagrangian and Hamiltonian dynamics. Participants explore the distinction between forces that can be directly derived from a Lagrangian and those that must be added to the equations of motion, such as frictional forces.
  • Some participants propose that velocity-dependent forces like the Lorentz force can be derived from a classical Lagrangian, while others, such as friction, cannot.
  • A participant mentions that if all forces can be derived from a potential, Lagrange's equation can be applied directly.
  • It is suggested that for forces not derivable from a potential, one can modify Lagrange's equation to include generalized forces.
  • Another participant emphasizes the need to distinguish between deriving forces from the Lagrangian and adding them to the right-hand side of the Euler-Lagrange equations.
  • There is a discussion about the conditions under which a velocity-dependent force can be directly obtainable from a Lagrangian, with references to specific forms of the Lagrangian and generalized forces.
Participants express differing views on the conditions for deriving velocity-dependent forces from a Lagrangian. There is no consensus on a definitive set of necessary and sufficient conditions, and the discussion remains unresolved.
Participants reference specific forms of Lagrangians and generalized forces, indicating that the applicability may depend on the specific system and forces involved. The discussion highlights the complexity of integrating non-conservative forces into the Lagrangian framework.
jdstokes
Hi,
I'm in the process of self-teaching myself Lagrangian and Hamiltonian dynamics. In my readings, I've found that some velocity dependent forces (e.g. the Lorentz force) can be derived from a classical Lagrangian whereas others such as friction cannot.
Do there exist necessary and sufficient conditions to decide when velocity dependent forces are obtainable from a Lagrangian, in the same way that velocity independent forces can be obtained from a lagrangian iff they are the gradient of a potential function?
James
jdstokes said:
Hi,
James
If all the forces on a system can be derived from a potential, you can use Lagrange's equation.
If you have forces that can't be derived from a potential, one has the option of re-writing Lagrange's equation (Goldstein, Classical mechanics, pg 23-24)
[tex] \frac{d}{dt} \left( \frac{\partial L}{\partial \dot{q_j}} \right) - \frac{\partial L}{\partial q_j} = Q_j[/tex]
where [itex]Q_j[/itex] is a generalized force that can include forces not derivable from a potential. In many cases, [itex]Q_j[/itex] can be specified via a dissipation function [itex]\mathcal{F}[/itex] so that [tex]Q_j = \frac{\partial \mathcal{F}}{\dot{q_j}}[/tex]
One then needs to specify L and [itex]\mathcal{F}[/itex] to get the equations of motion.
Hi pervect,
Thanks for the reply.
I think we need to distinguish between deriving forces from the Lagrangian and adding them directly to the RHS of the E-L equations.
For the Lorentz force, we start with the Lagrangian [itex]L = (1/2)m \dot{\mathbf{r}} \cdot \dot{\mathbf{r}} + e V(\mathbf{r},t) + e \dot{\mathbf{r}}\cdot \mathbf{A}(\mathbf{r},t)[/itex] and then apply the standard, unmodified E-L equation [itex]\frac{d}{dt}\frac{\partial L}{\partial \dot{\mathbf{r}}} - \frac{\partial L}{\partial \mathbf{r}}[/itex] to obtain the velocity-dependent Lorentz force [itex]m\ddot{\mathbf{r}} = e[\mathbf{E} + \dot{\mathbf{r}}\times \mathbf{B}][/itex]. So we can say that these equations of motion are obtainable directly from a Lagrangian.
If we consider linear frictional forces, on the other hand, we cannot obtain these directly from a Lagrangian, we must add them in later to the RHS of the E-L equations as you describe.
My question: what determines whether a velocity-dependent force is directly obtainable from a Lagrangian?
Thanks
James
The second to last line in the derivation of Lagrange's equations is:
[tex]\frac{d}{dt}\left(\frac{\partial T}{\partial \dot q_i} \right) - \frac{\partial T}{\partial q_i} = Q_i[/tex]
where Q_i is the generalized force. Then if there is a function V(q_1,...,q_n,t) with:
[tex]\frac{\partial V}{\partial q_i} = - Q_i[/tex]
Then you get lagrange's equations (note this holds in one coordinate system iff it holds in all of them). But more generally, as long as you can find a function [itex]V(q_1,...,q_n,\dot q_1,...,\dot q_n,t)[/itex] with:
[tex]Q_i = \frac{d}{dt}\left(\frac{\partial V}{\partial \dot q_i} \right) - \frac{\partial V}{\partial q_i}[/tex]
Then you can just take it as your V when you define L=T-V and you get the correct equations. It can be shown that the lorentz force is of this form with:
[tex]V = q \phi - q \vec v \cdot \vec A[/tex]
14K
16K
  • · Replies 16 ·
15K
