Net electrostatic force on particle 3 in a square charge configuration
2 replies · 3K views · last reply
UNG
SORRY POSTED UNDER WRONG TOPIC = Delete thanks
Hi, I would appreciate it if someone could help me with this question, I am a n00b here
Please and thank you
Okay here's the question.
The particles have charges Q1 = -Q2 = 100nC and Q3 = -Q4 =200nC
and distance a = 5.0cm.
What are the x and y components of the net electostatic force on particle 3 ?
So basically a diagram is given with the question showing the 4 particles equally separated from each other at a distance of 5.0cm, making a square. And I have to find the force on particle 3.
This is the equation I used.
F1,3 = (8.854x10^-12) x (Q1 x Q3)/0.0707xR^2 (0.0707 comes from Phyagrous therom)
H= (square root) 0.05^2 + 0.05^2
F1,4 = (8.854x10^-12) x (Q1 x Q4)/0.0707xR^2
Fnet = F1,3 + F1,4
= F1,3 + (8.854x10^-12) x (Q1 x Q3)/R^2 Cos 45 (45 degrees middle of square)
+ (8.854x10^-12) x (Q1 x Q4)/0.0707xR^2 Sin 45
I have a feeling this is seriously wrong and have made it more complicated than it is.
I placed the values into the equation shown and came out with
= -79.46 x10^3 + 79.46 x10^3
Heres a site I found afterwards...
http://physics.bu.edu/~duffy/PY106/Charge.html
I think it might go a little something like that instead^^
If you could help that would be great thanks.
Hey,
This is a rather straight-forward problem essentially all you need to do is sum up the forces on particle 3 in the x and y directions.
To get you started here is the general form for the superposition of forces (summing of force vectors).
[tex] \sum{\vec{F}_{m}} = {\sum_{i=1}^{n}}{\vec{F}_{mn}}[/tex]
So,
[tex] \sum{\vec{F}_{3_{}}} = {\vec{F}_{31_{}}} + {\vec{F}_{32_{}}}[/tex]
Breaking into the x-components,
[tex] \sum{\vec{F}_{3_{x}}} = {\vec{F}_{31_{x}}} + {\vec{F}_{32_{x}}}[/tex]
[tex] \sum{\vec{F}_{3_{x}}} = {\left(\frac{{k_{e}}{|q_{3}|}{|q_{1}|}}{{{r}_{31}}^{2}}\right)}{cos{\theta_{31}}}{\hat{i}} + {\left(\frac{{k_{e}}{|q_{3}|}{|q_{2}|}}{{{r}_{32}}^{2}}\right)}{cos{\theta_{32}}}{\hat{i}}[/tex]
From here you can use the symmetry of the problem to find your distances and evaluate.
Thanks,
-PFStudent
Thanks, those are the forumulas I used.
Made a silly few mistakes though
