PCA and variance on particular axis
To calculate the variance of 3D point data along a random direction, one must understand the relationship between quadratic forms and statistical properties. The discussion highlights that manipulating quadratic forms through orthogonal transformations can reveal useful statistical insights. It emphasizes the significance of orthoprojections in determining means and variances in a geometrical context. Additionally, caution is advised regarding the interpretation of PCA, as its geometric manipulations may not always yield statistically valid conclusions. Understanding these concepts can enhance the application of statistical methods in data analysis.
Asuralm
Hi All:
If given a set of 3D points data, it's very easy to calculate the covariance matrix and get the principle axises. And the eigenvalue will be the variance on the principle axis. I have a problem that if given a random direction, how do I calculate the variance of the data on the given direction?
Can anybody help me with this please?
Thanks
Mathematics news on Phys.org
Speaking of Applicable Geometry
How much do you know about the relationship between euclidean geometry and mean/variance?
Your question really concerns the values taken by a quadratic form. Many statistical manipulations (and many useful properties of normal distributions) arise in a geometrically natural manner from manipulating quadratic forms by orthogonal transformations and orthoprojections, together with some notions from affine geometry such as convexity. For example, taking the mean of n variables x_1, \, x_2, \dots x_n, where we think of this data as the vector \vec{x} = x_1 \, \vec{e}_1 + \dots x_n \, \vec{e}_n, corresponds to taking the orthoprojection (defined using standard euclidean inner product) onto the one dimensional subspace spanned by \vec{e}_1 + \vec{e}_2 + \dots \vec{e}_n. If we adopt a new orthonormal basis including the unit vector \vec{f}_n = \frac{1}{\sqrt{n}} \, \left( \vec{e}_1 + \vec{e}_2 + \dots \vec{e}_n \right), this orthoprojection can be thought of very simply, as simply forgetting all but the last component \sqrt{n} \, \overline{x}, which agrees (up to a constant multiple) with the arithmetic mean.
See M. G. Kendall, A Course in the Geometry of n Dimensions, Dover reprint, and then try the same author's book Multivariate Analysis.
I must add a caution: do you see why principle component analysis (PCA) is essentially a method for "lying with statistics"? That is, the geometric (or if you prefer, linear algebraic) manipulations of your data set are mathematically valid, but the statistical interpretation is almost always extremely dubious. Fortunately, my remark about the role of euclidean geometry in mathematical statistics holds true for many more legitimate statistical methods, some discussed in the first book by Kendall cited above.
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
