Intrest rates/investment problem (pert), I just need someone to check my work
  • Thread starter Thread starter KatieLynn
    Check my work Work
Cindy needs to determine how much to ask her parents for now to have $10,000 in three years, using the formula P=Ae^(-rt), which results in approximately $6,977 at a 12% continuous compounding rate. Carla's inherited building, valued at $250,000, is projected to appreciate at 25% annually for four years, leading to a future value of about $679,570. The profit from waiting to sell the building instead of selling it now is calculated to be $429,570. However, the correct rate for Carla's investment should be 25%, not 12%. The calculations for both scenarios are validated, with the only error being the interest rate used in the second problem.
KatieLynn
intrest rates/investment problem (pert), I just need someone to check my work:)
1)Cindy requires $10,000 in 3 years to return to college to get and MBA degree. How much money should she ask her parent for now so that, if she invests it at 12% compounded continuously, she will have enough for school?
2)Carla just inherited a building that is worth $250,000. The building is in a high demand area, and the value of the building is projected to increase at a rate of 25% per year for the next 4 years. How much more money will she make if she waits for four years to sell the building instead of selling it now?
P=Ae^(-rt)
1)so the equation would be
P= (10,000)e^(-.12*3) which equals $6,977 correct?
2)A=Pe^(rt)
A= $250,000e^(.12*4) = $679,570
so then $679,570-$250,000=$429,570
is all that correct?
Yes.
2)A=Pe^(rt)
Other than r = 25% not 12%, yes.
ah yeah I did the math right, I just typed in the wrong rate for the second one
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
