Solving General Questions: F, CG, I, Torque, Acceleration
  • Thread starter Thread starter srose9625
    General
The discussion revolves around solving various physics problems related to forces, torque, and acceleration. Participants seek clarification on calculating upward forces on a bridge, the mechanics of a seesaw, the minimum angle for a ladder to avoid slipping, net torque for a rotating disk, and the acceleration of a falling bucket. Key insights include the importance of drawing diagrams to visualize forces and moments, understanding the balance of forces in static situations, and recognizing that moment of inertia cannot be ignored in torque calculations. Overall, the thread emphasizes the necessity of applying fundamental physics principles to solve these mechanics problems effectively.
srose9625
1). A uniform bridge span weights 50x10^3 N and is 40m long. An automobile weighting 15x10^3 N is parked with its center of gravity located 12m from the right pier. WHat upward force does the left pier provide? The answer is 29.5x10^3 N but how do I get that?
my attempt: F - (50000N)(20m) - (15000N)(8m)=0
2). Tasha has a mass of 20kg and wants to use a 4m board of mass 10kg as a seesaw. Her friends are too busy, so Tasha seesaws alone by putting the support at the systems center of gravity, she sits on one end of the board. How far from the support point is she? The answer is .67m, but how is this problem done?
my atempt: -(10kg)(2m)- (20kg)(x)(9.8)=0
3). A 100N uniiform ladder, 8m long rests against a smooth vertical wall. The coefficient of static friction between the ladder andthe floor is 0.40. What minimum angle can the ladder make with the floor before it slips? THe answer is 51'
my attempt: NO CLUE
4). A disk has a moment of inertia of 3x10^-4 kg.m2 and rotates with an angular speed of 3.5rads/sec. What net torque must be applied to bring it to rest within 3 seconds?
The answer is 3.5x10^-4 N.m but how do they get this answer?
my attempt: I know that the I is very small so we can ignore it
5). A buket of water with a total mass of 23kg is attatched to a rope, which in turn is wound around a 0.050m radius cylinder at thetop of a well. A crank with a turning raidus of 0.25m is attached to the end of the cylinder and the moment of inertia of the cylinder and the crank is 0.12kg.m2. If the bucket is raised to the top of the well and released, what is the acceleration of the bucket as it falls toward the bottom of the well?
The answer is 3.2m/s2 but how?
my attempt: NO CLUE
You cannot do any problem in mechanics without having a picture of what is happening and where the forces are.
You also need to know that the moment = force * distance (at right angles to force)
if a see-saw is not moving then the moment on both sides balances.
1, Draw the diagram with the car in the middle, show the forces and work out the force n each pier. Now draw the forces with the car ontop of the right pier.
Think about what happens as the car moves toward the 12m point (hint think ratios)
2, For the girl to see-saw herself then her+part of plank on her side must balnace part of plank on other side.
3, The sideways force needed to overcome friction is coeff_friction * normal force.
Normal force is the force downward on the sliding part.
4, You can't ignore I - it's a multiplication. If I were negligible it would take no torque to bring it to a stop instantly.
5, F = m a. The acceleration downward on the bucket is g (9.8m/s^2)
What force is needed to turn the crank ?
1. I have drawn this diagram and still no clue. I have played with the numbers for DAYS.
2. I understand that part
3.?
4. I GOT it:) Tnet=(I)(speed) / time
5. ?
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
