A hydrogen atom in a weak time-dependent perturbation
The discussion focuses on the effects of a weak time-dependent electric field on a hydrogen atom in its ground state. Participants explore the selection rules for transitions from the ground state using time-dependent perturbation theory, specifically looking at possible final states characterized by quantum numbers n, l, and m. The perturbation potential is defined, and there is a detailed examination of the mathematical expressions needed to calculate transition probabilities, particularly from the 1s to the 2p state. Key points include the use of spherical harmonics and the importance of angular momentum coupling in determining allowed transitions. The conversation emphasizes the need for accurate integration and understanding of the underlying quantum mechanics principles.
Urvabara
A hydrogen atom, which is in its ground state 1s (i.e. \|1,0,0\rangle), is put into a weak time-dependent external electric field, which points into the z direction:
\boldsymbol{E}(t,\boldsymbol{r}) = \frac{C\hat{\text{\boldsymbol{e}}}_{z}}{t^{2}+\tau^{2}}, where C and \tau > 0 are constants. This gives rise to a perturbation potential V(t) = C\frac{e\hat{z}}{t^{2}+\tau^{2}}, where e denotes the electron charge.
(a) Using lowest-order time-dependent perturbation theory, find the selection rules for transitions from the ground state, i.e. find out which final state values for the quantum numbers n, l and m are possible in transitions from the ground state.
(b) Calculate the probability of transition from the ground state 1s to to the state 2p during an infinitely long period of time, setting t_{0}\rightarrow -\infty and t\rightarrow\infty.
This is useful, isn't it?
P_{fi}(t,t_{0})\equiv |\langle\phi_{f}|\psi(t)\rangle|^{2}\approx \frac{1}{\hbar^{2}}\left|\int_{t_{0}}^{t}\text{d}t_{1}\langle\phi_{f}|V_{S}(t_{1})|\phi_{i}\rangle \text{e}^{\text{i}(E_{f}-E_{i})t_{1}/\hbar}\right|^{2}.
(b) I probably should use the equation given in the section "2. Homework Equations " and "sandwich" perturbation potential between the states \langle 2,1,m| and |1,0,0\rangle, shouldn't I? What m-value should I use?
Any hints to (a)?
Any hints to (a)?
what kind of spherical tensor is z? What is its rank?
Then you will get your selection rules, so you know what m values you should use for the matrix elements (i.e the set if final states that can be reached)
You might want to look in the chapter of tensor operators in your textbook.
Or you can write z as a spherical harmnonics and use the wave functions for the hydrogen-states (that is a radial part times a spherical harmonic) and use some well known spherical harmonics identities.
EDIT: You might also use parity relations for the Spherical harmonics, if you are not allowed to use collection of formulas for spherical harmonics.
Urvabara said:
Any hints to (a)?
How's it going?
malawi_glenn said:
How's it going?
Thanks for your reply!
I think that z = r_{0} = r\cos (\theta). Right?
I also think that \langle 2,1,m|r_{0}|1,0,0\rangle = \sqrt{\frac{4\pi}{3}}\langle 2,1|r_{0}|1,0\rangle\langle 1,m|Y_{10}(\theta ,\phi)|0,0\rangle Right?
The radial part is easy to calculate: \langle 2,1|r_{0}|1,0\rangle = \int_{0}^{\infty}r^{3}R^{*}_{21}(r)R_{10}(r)\,\text{d}r = ... Right?
The angular part is: \langle 1,m|Y_{10}(\theta ,\phi)|0,0\rangle = \sqrt{\frac{3(2*0+1)}{4\pi (2*1+1)}}\langle 0,1;0,0|1,0\rangle\langle 0,1;0,0|1,m\rangle Right?
The C-G coefficients \langle 0,1;0,0|1,m\rangle vanish unless m=0+0=0 and 0-1\leq 0 \leq 0+1 or \Delta m = m-0 = 1,0,-1 and \Delta l = 1-0=1 Hmm. Right?
PS. Sorry, because my reply is so late. I was somewhat busy.
I think that z = r_{0} = \cos (\theta). Right?
You have some errors that you need to fix.
z = r\cdot \cos \theta
and the "selection" rules from CG are:
m = m_1 + m_2
and
|j_1 - j_2| \leq j \leq j_1 + j_2
so z is essential r \cdot Y_{l=1}^{m=0}, which is a spherical tensor of rank (k) = 1, with q = 0
The so called m-selection rule is:
<\alpha , j_1,m_1 |T^{(k)}_{m}|\beta , j_2, m_2> = 0 ; unless m_1 = q + m_2
So now you know which final state your pertubation can take the initial state (the ground state in this case).
Then you just evaluate the integrals, you can look up explicit wave functions for the hydrogen atoms in your textbook and just do the math, straighforward but lenghty. Remember to use spherical coordinates when you integrate.
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
