A few questions about the Taylor series
The Taylor series represents a function as an infinite sum of terms derived from its derivatives at a single point. It can converge to a function, but this convergence may only occur within a specific neighborhood around that point. If the series converges, its domain and range align with those of the function it represents. However, not all Taylor series converge, and even when they do, they might not equal the function everywhere. Understanding the conditions of convergence is crucial for grasping the relationship between a series and the function it approximates.
Shing
When I tried to learn the Taylor series , I could not comprehend why a infinite series can represent a function
Would anyone be kind enough to teach me the Taylor series? thank you:smile:
the Taylor series is a representation of a function as an infinite sum of terms calculated from the values of its derivatives at a single point.
\sum_{n=0}^\infty \frac{f^{(n)}(a)}{n!}(x-a)^n
PS. I am 18 , having the high school Math knowledge including Calculus
Mathematics news on Phys.org
you can also consider a serie as a function
f(x) = \sum_0^{\infty} \frac{f^{(n)(a)}}{n!}(x-a)^n
if the sum converges this is nothing but a function, to each x you get a number, namely the sum of the series.
Mayby an example is in place.
Lets say we define a function by
f(x) = \sum_0^{\infty} (g(x))^n
where g: \mathhb{R} \rightarrow ]0,1[, is this series a function you could say. But because the range of g i ]0,1[ this is just the geometric series, that is
f(x) = \sum_0^{\infty} (g(x))^n = \frac{1}{1-g(x)}
so this is indeed a function. So you see that a series is a function if the sum converges. It's although not always possible to find a so simple expression like here for the serie.
a little text from wikipedia
The Taylor series need not in general be a convergent series, but often it is. The limit of a convergent Taylor series need not in general be equal to the function value f(x), but often it is. If f(x) is equal to its Taylor series in a neighborhood of a, it is said to be analytic in this neighborhood. If f(x) is equal to its Taylor series everywhere it is called entire.
Shing said:
thank you for your help
But I don't really got it..
A function has its own domain and range... but what is the domain and range of a series?
?? If a series converges to a function, then it's domain and range are exactly that of the function, of course. A series, depending on a variable x, is a function. You seem to think there is something special about using a series to define a function.
you are right, but sometimes the taylor series only converges in a neigborhood around the point a, and sometimes it doesn't converges at all. So to say that if the series converges then it is equal to the function is a bit loose, I agree on that for those x where the series converges, then on those x they agree. Actually that is probably what you meen, but just to make it clear.
I didn't say that! I said that if a series converges, it is necessarily equal to a function. I didn't say anything about the series being a Taylor's series.
