What causes errors in experimental calculations of x?
  • Thread starter Thread starter j-lee00
    Error
Errors in experimental calculations of x arise from inaccuracies in the variables s, a, and b. The derived formula for relative error is Δx/x = sqrt((1/(4ab)^2)*[(bΔa/a)^2+(aΔb/b)^2]+(Δs/s)^2). A participant questions the absence of "z" in the final result, suspecting a typo. The logarithmic transformation of the equation clarifies the relationship between the variables, leading to a differential expression that incorporates the errors. It is noted that "z" does not contribute to the error, as it has no associated variability.
j-lee00
x = s(sqrt((2(a+b))/zab)
There is error in s, a and b
show the required result is
\Deltax/x = sqrt( (1/(4ab)^2)*[(b\Deltaa/a)^2+(a\Deltab/b)^2]+(\Deltas/s)^2
Mathematics news on Phys.org
What happened to the "z" in the denominator? I don't see it in the result? Is it a typo?
Try this: take the logarithm of both sides so
ln(x)= ln(s)+ (1/2)[ln(2)+ ln(a+b)- ln(a)- ln(b)- ln(z)]
Now take the differential:
dx/x= ds/s+ (1/2)[(da+db)/(a+b)- da/a- db/b- dz/z] and replce each "d" with "\Delta.
z has no error associated with it
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
