Probability Theory 2: Finding Mean and Variance of X_n on Real Line
An individual traveling on the real line aims to reach the origin, with each step having a mean of 0 and a variance of βx². The position after n steps, denoted as X_n, starts from an initial position X_0 = x_0. For part a, the expected value E[X_n] is determined to be 0 due to the mean of each step being 0. In part b, the variance Var(X_n) is discussed, with the understanding that it changes with each step rather than remaining constant. The conversation emphasizes the importance of recognizing how variance maps from one step to the next, ultimately leading to a deeper understanding of the problem's requirements.
Milky
An individual traveling on the real line is trying to reach the origin. However, the larger the desired step, the greater is the variance in the result of that step. Specifically, whenever the person is at location x, he next moves to a location having mean 0 and variance \beta x^2. Let X_n denote the position of the individual after having taken n steps. Supposing that X_0 = x_0, find
a. E[X_n]
b. Var(X_n).
I am not sure how to even start this problem, and would really appreciate any suggestions!
Did you mean:
"whenever the person is at location xn, he next moves to a location xn+1 with error having mean 0"?
No, I copied exactly what the book said. I'm so confused!
Okay. Part a is easy. The problem gives away the answer. (The answer is stated unambiguously as part of the problem statement.)
For part b, what does the definition of variance say? (E.g. Var[x] = b x^2.)
Okay, so for part a, E[Xn] = 0 because with every step the mean is 0...right?
For part b.. I'm still not sure.
I know Var(X) = bx^2, but I don't know how to get from X to Xn. I tried using the definition of variance: E[X^2] - (E[X])^2 but it didn't get me very far
The question is, if you know Xn, do you need to know X0, ..., X(n-1) to know Var(Xn)?
The variance is the same for each step that he takes, so why wouldn't the variance just still be bx^2?
No, the variance changes with each step, unless you happen to stay where you are (which is highly improbable). Look at the definition of the variance. It maps x to bx^2. Suppose Xn = t. Where does it map t?
bXn^2 ?
Yes.
