How Long Could Gravitational Contraction Power the Sun?
Tuugii
The gravitational potential energy W of a self-gravitating sphere of mass M and radius R depends on the detailed distribution of mass within the sphere, but it is generally of order of magnitude -GM^2/R. For the Sun, W_sun = -2G(M_sun)^2/R. What is the timescale
t = -(1/2)(W_sun)/(L_sun) over which gravitational contraction could have supplied the power radiated by the sun at it's present rate?
please give some hints, thanks a lot.
what is L_sun ?
(iknow that it is Luminosity, but try to find the value)
malawi_glenn said:
what is L_sun ?
thanks for the reply. But I didn't understand what was your hint... :)
I meant, have you tried just to plug in the value of L_sun into that eq?
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
