Comparison of attraction/repulsion measures
  • Thread starter Thread starter fer2000
    Comparison
To analyze the attraction/repulsion data across multiple matrices, a paired-comparison t-test or ANOVA is suggested, depending on the specifics of the data. The matrices are symmetrical, and the goal is to determine how closely the first matrix resembles the second compared to the third. The analysis must account for the size of the matrices, which are approximately 300 x 300. The time lapse between situations is not a concern, but consistency in external conditions is necessary for valid comparisons. Understanding the connection to quantum physics remains an open question in the discussion.
fer2000
Hello everybody!
I have a large set of items and, two-by-two, there exists some kind of attraction/repulsion that I have measured.
Under different circumstances this attraction/repulsion changes.
So, what kind of statistical/mathematical procedure can I use to measure whether the changes (for the whole set) are “large/small”, as well as if a subset of them (lets say the first ten items) the attraction is larger than in another subset (lets say the last ten items)?.
Thanks in advance
First, you should provide a much more detailed description of your experiment. My initial thought would be a paired-comparison t-test; possibly an ANOVA approach. Much depends on what you do -- if time is involved, then the analysis can be tricky because of possible autocorrelations. Details, details, details.
Regards,
Reilly Atkinson
Hello, first of all, thanks for your answer.
The situation is as follows,
My data are comprised in different matrices (each of the situations provide that information).
First one
x 1.3 -1.5 . . . . . .
1.3 x 1.2 . . . . . .
-1.5 1.2 x . . . . . .
Second one
x 1.1 1.3 . . . . . .
1.1 x -0.2 . . . . . .
1.3 -0.2 x . . . . . .
Third one
x -0.1 0.3 . . . . . .
-0.1 x 0.4 . . . . . .
0.3 0.4 x . . . . . .
All of them are symmetrical and the diagonal does not make sense (I could write any number). Note that the dimension will be around 300 x 300 for each matrix.
How can I say if first one is closer (and how closer is) to second one than to third one (as well as any other combination)?
I do not mind the lapse of time between each of the situations (that provide each of the matrices), but an external condition that is the same for all the pairs that generate the matrix.
Thanks again.
Just out of curiosity, what is the connection of this with quantum physics?
Thread 'Gauss' law seems to imply instantaneous electric field'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
