Hydrostatics physics question
This may not be a practical or safe solution, so it would be important for the girl to learn how to swim or use flotation devices instead. In summary, to keep her head 3 liters above the water surface, a girl of mass 40 kg and volume of 40 liters would need to add approximately 39.6 kg of air to her jacket. However, this may not be a practical or safe solution and it would be important for her to learn how to swim or use flotation devices instead.
sovankc
A girl of mass 40 kg and volume of 40 liter wants to keep her head of volume 3 liter above water surface as she can't swim . how much air in Kg should she fill in her jacket??
mass of girl (m) = 40 kg
volume of girl (V) = 0.04 m^3(meter cube)
density of girl (D) = m / V = 1000 kg/m^3
volume of head (v') =0.003 m^3
let the mass of air in kg be x then
total mass of body = 40 + x
mass of water displaced = 40 + x
volume of water displaced = 1000(40 + x)
then
volume of immersion = V - v' = .04- .003 = .397
therefore from principle of flotation
volume of water displaced = volume of immersion of floating body
40000 + 1000x = .397
x=.397-40000 = -ve value
is my method correct? and as " density of body = density of water " will require extra air to float.
Your method is generally correct, but there are a few things to consider. First, it is important to clarify that the volume of the girl's head should be added to the volume of her body (40 liters) to find the total volume of her body. This would give a volume of 43 liters, or 0.043 m^3.
Next, the density of the girl's body should be calculated using her total volume, not just her body volume. This would give a density of 930.23 kg/m^3, which is slightly less than the density of water (1000 kg/m^3). This means that the girl's body will naturally float in water, without needing any additional air in her jacket.
However, if we want to lift her head 3 liters above the water surface, we do need to add some air to her jacket. To find the mass of air needed, we can use the equation you set up:
(40 + x) = 0.397
Solving for x, we get x = -39.603 kg. This is a negative value because we are technically removing this amount of mass (air) from the girl's body in order to lift her head above the water surface.
So, to answer the original question, she would need to add approximately 39.6 kg of air to her jacket in order to keep her head 3 liters above the water surface.
1. What is hydrostatics?
Hydrostatics is a branch of physics that deals with the study of fluids at rest and the forces exerted by these fluids on objects immersed in them.
2. What is the principle of hydrostatics?
The principle of hydrostatics states that the pressure at any point in a fluid at rest is the same in all directions, and it increases with depth due to the weight of the fluid above.
3. How is the pressure in a fluid calculated?
The pressure in a fluid is calculated using the formula P = ρgh, where P is pressure, ρ is the density of the fluid, g is the acceleration due to gravity, and h is the depth of the fluid.
4. What is Pascal's law in hydrostatics?
Pascal's law states that when there is an increase in pressure at any point in a confined fluid, there is an equal increase in pressure at every other point in the fluid.
5. How does hydrostatics apply to everyday life?
Hydrostatics has many practical applications in everyday life, such as in plumbing, swimming, and weather forecasting. It also helps in understanding the behavior of fluids in various industries, including aviation, oil and gas, and marine engineering.
  • General Math
