Independent and interacting electron models
Nusc
Why is it that we can treat electrons as independent and non-interacting in solid state physics?
What is the difference between mean-field theory and density functional theory?
In lame terms please.
Okay forget lame terms.
Suppose you're considering a system of noninteracting fermions (e.g., electrons with no coulomb interactions), called a Fermi Gas. Since this system is non-interacting, it's possible to solve for the energy spectrum of this system. In a real system, of course, the electrons are interacting, so imagine that you started with this Fermi gas system and slowly turned on the coulomb interaction. In doing so, the eigenstates of the Fermi Gas system (that is, the various characteristic energy states of the system) will evolve adiabatically into the eigenstates of the interacting system. So, there is a mapping from the eigenstates of the non-interacting system to the eigenstates of the interacting system. Strictly speaking, then, electrons themselves aren't actually treated as independent and non-interacting - the system is actually described in terms of "quasiparticles", elementary excitations of the system with the same quantum numbers as the non-interacting electrons, which may be treated as non-interacting. The quasiparticle description is obtained through this adiabatic evolution of eigenstates.
This process is called "Landau's adiabatic switching on procedure". There are some caveats I didn't mention, mainly because I don't remember them all but also because they wouldn't be too enlightening as part of a basic description. If I recall correctly this switching-on procedure isn't strictly necessary, but is the fastest way to get to the quasiparticle description of the system.
Sometimes this is the case, and sometime it is not. this is actually an assumption, which does not always turn out to be true. If the assumption is true then we say we are dealing with a "normal" Fermi liquid.
Yes, this is one of the caveats I didn't mention, since I don't know much about non-normal Fermi Liquids.
From the BCS theory of superconductivity is well known that the superfluid density smoothly decreases with increasing temperature. Annihilated superfluid carriers become normal and lose their momenta on lattice atoms. So if we induce a persistent supercurrent in a ring below Tc and after that slowly increase the temperature, we must observe a decrease in the actual supercurrent, because the density of electron pairs and total supercurrent momentum decrease. However, this supercurrent...
Hi. I have got question as in title. How can idea of instantaneous dipole moment for atoms like, for example hydrogen be consistent with idea of orbitals? At my level of knowledge London dispersion forces are derived taking into account Bohr model of atom. But we know today that this model is not correct. If it would be correct I understand that at each time electron is at some point at radius at some angle and there is dipole moment at this time from nucleus to electron at orbit. But how...
