Why is 1+i = root 2e^(pi/4+2pi k) true?
  • Thread starter Thread starter The_ArtofScience
The discussion centers on the identity 1+i = √2e^(π/4 + 2πk), exploring the complexities of imaginary numbers and their representation in the complex plane. The original poster expresses confusion over this identity, particularly regarding its implications for cosine and sine values on the unit circle. It is clarified that complex powers can yield multiple values due to the multi-valued nature of complex arguments, as illustrated by the example of i^i. The conversation emphasizes the importance of understanding these nuances when dealing with complex numbers and their properties. Ultimately, the identity holds true when considering the modulus and argument of complex numbers.
The_ArtofScience
Imaginary numbers have always intrigued me from the very beginning I was taught to believe that some negative root number could have an "i" factored out!
Anyway, I like to know more about this identity if anyone can help me out:
(1+i)^(1+i) = e^ln(root 2)-pi(1/4+2k)e^i(ln(root2)+pi(1/4+2k))
I'm not quite sure as to how 1+i = root 2e^(pi/4+2pi k). I do know that i^i = e^-pi/2 from the identity e^ipi=-1 which gives i = ln(-1)/pi. So my question is why is 1+i = root 2e^(pi/4+2pi k) true? This statement does not seem to make sense to me because it describes both cosine and sine giving 1 as an answer which does not seem to be the case on the unit circle and neither from Euler's identity
Mathematics news on Phys.org
1 + i is not root 2.
Ha! Sorry found out my own answer
1+i is really just a case of a+ib on the complex xy plane. The modulus can be calculated using (a^2+b^2)^1/2 and the argument can be done using the fact that tangent = b/a
edit:Yes, dx I'm aware of that. I changed it after you made your post
Complex powers are not what they seem. You stated that i^i=e^-pi/2, in fact i^i has infinitely many values:
i^i=e^{ilogi}=e^{i(i(\frac{\pi}{2}+2k\pi))}=e^{-\frac{\pi}{2}}e^{-2k\pi}
Where k is an integer. This 'multi-valuedness' arises from the fact that the argument of a complex number is 'multi-valued', adding an integer multiple of 2pi to the angle a complex number makes with the positive x-axis (real axis) gives you the same number.
Moral of story: Beware of complex powers!
Edit: woops in my haste i forgot to re-read your 3rd line which shows you have taken into account the multivaluedness.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
