Conditional Probability in a card game
The discussion revolves around calculating the probability of drawing fewer red cards from a deck after removing one red card compared to leaving it in. The user has already computed the probabilities for drawing 0-7 red cards in both scenarios using hypergeometric distribution. There is uncertainty regarding how to interpret the results and whether the question involves conditional probability. The conversation highlights the need for clarity on the question's framing, particularly regarding the comparison of probabilities when no red cards are removed. Understanding these probabilities is crucial for determining the impact of removing a card on the hand composition.
SiegeX
Although this problem may look like homework, I assure you it is not. It is a question that arose from a trading card game that I am stuck on. The problem is as follows (with simplified cards)
You have a deck of 53 cards, and 11 of those cards are red and 42 are black. If you were to randomly draw 7 cards from the deck, how often would your hand of 7 have *less* red cards in it if you had removed 1 red card from the deck prior to drawing your cards compared to leaving it in?
I'm fairly certain this is a hypergeometric distribution and I have calculated the probabilities of drawing 0-7 red cards in a hand of 7 with 11 red cards in a 53 card deck as well as the probability of drawing 0-7 red cards in a hand of 7 with 10 red cards in a 52 card deck. These numbers are listed below. Where to go from here I am not sure. This seems to be a conditional probability but there shouldn't be any dependence since the 7 drawn cards are replaced on each trial.
Code:
	0	1	2	3	4	5	6	7
53	17.50%	37.44%	30.35%	11.98%	2.46%	0.26%	0.01%	0.00%
52	20.17%	39.21%	28.61%	10.04%	1.80%	0.16%	0.01%	0.00%
First of all, I get a different chart from yours, starting
Code:
19.63%  35.98%  28.27%
I'll need more context before I can understand you. Let's say your question was "how often would your hand of 7 have *less* red cards in it if you had removed 0 red cards from the deck prior to drawing your cards compared to leaving it in?" (bold part changed). Would the answer to this question be 0 (since the probabilities would of course be the same) or positive (since some hands would improve)?
I was reading documentation about the soundness and completeness of logic formal systems. Consider the following $$\vdash_S \phi$$ where ##S## is the proof-system making part the formal system and ##\phi## is a wff (well formed formula) of the formal language. Note the blank on left of the turnstile symbol ##\vdash_S##, as far as I can tell it actually represents the empty set. So what does it mean ? I guess it actually means ##\phi## is a theorem of the formal system, i.e. there is a...
