Technical question: vanishing of the cosmological constant in Randall Sundrum 1
nrqed
This is a very technical question so I don't really expect someone to have the answer unless they have actually worked with or studied the RS models.
They say that the value of the brane tensions in model 1 (which are related to the bulk cosmological constant) are such that the 4D cosmological constant (on our brane) is zero.
I can't see how this comes about.
I probably misunderstand but the way i see it, there are two contributions to the 4D cosmological constant: the brane tension itself plus the integral over the fifth dimension of the 5D cosmological constant. But when I do the integral, the two terms do not cancel out (there is a mismatch by a factor of 2). I could show my calculation but I will wait to see if anyone can help.
Thanks
PhysiSmo said:
Could you pinpoint us the original paper? Also, check out this review,
http://arxiv.org/abs/hep-th/0209261,
it's one of the best I've found for the subject.
Yes, this is a very good introduction. Unfortunately, it is not shown that the 4D cosmological constant in the original RS model is zero.
The two original RS papers are
http://arxiv.org/abs/hep-ph/9905221
and
http://arxiv.org/abs/hep-th/9906064
If I recall, in the first one they don't say explicitly that the 4D cosmological constant is zero.
In the second paper, they do say it and seem to imply that it follows trivially from the value of the brane tension and the constant appearing in the warp factor.
Thanks
I think they're just looking at Minkowski slices of AdS space, so the 4d cosmological constant is automatically 0.
This is an alert about a claim regarding the standard model, that got a burst of attention in the past two weeks. The original paper came out last year: "The electroweak η_W meson" by Gia Dvali, Archil Kobakhidze, Otari Sakhelashvili (2024) The recent follow-up and other responses are "η_W-meson from topological properties of the electroweak vacuum" by Dvali et al "Hiding in Plain Sight, the electroweak η_W" by Giacomo Cacciapaglia, Francesco Sannino, Jessica Turner "Astrophysical...
https://arxiv.org/pdf/2503.09804 From the abstract: ... Our derivation uses both EE and the Newtonian approximation of EE in Part I, to describe semi-classically in Part II the advection of DM, created at the level of the universe, into galaxies and clusters thereof. This advection happens proportional with their own classically generated gravitational field g, due to self-interaction of the gravitational field. It is based on the universal formula ρD =λgg′2 for the densityρ D of DM...
