How Long Does it Take to Generate 100MW with a Generator?
  • Thread starter Thread starter karthikgnv
    Generators
A generator rated at 100MW produces energy continuously at that rate, meaning it generates 100MWh of energy in one hour when fully loaded. The term MW refers to the power output rate, not the total energy produced over time. The time it takes for a generator to reach full power can vary based on the specific model and operational conditions. Understanding these distinctions is crucial for evaluating generator performance and energy billing. Overall, the generator's capacity indicates its instantaneous power output rather than a cumulative energy total.
karthikgnv
Hi all...people always tell that the machine has a generating capacity of say 100MW..now... my doubt is..in how much time it generates those 100MW..that is in a day or in an hour something like that?
This may be a basic doubt...i don't know..but i can't help it...
Thanx
Thanx
Assuming it is loaded with a 100MW consumer, the generator will produce 100MW at any given time. In one hour, it will have generated 100MWh or megawatthours of energy..for which the user will be charged...if it is a commercial generator.
To put it another way, MW is a rate of energy generation, not a quantity of energy generated.
How much time does it usually take for a generator that size to turn on to full power when activated?
Thanx
100MW = 100,000,000 Million Joules per SECOND
Equivalent to 3.1556926 * 10^15 joules per YEAR
thanx for the info guys
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
