Prove Limit of f(x)=x4: Proving a=a4
  • Thread starter Thread starter tanzl
    Definition Limit
The discussion revolves around proving the limit of the function f(x) = x^4 as x approaches a, specifically showing that lim (f(x), x=a) = a^4. Participants are exploring the mechanics of limit proofs and expressing the limit in terms of epsilon and delta.
  • Participants discuss the need to express |f(x) - a^4| in terms of delta and explore the implications of choosing delta in relation to epsilon. There are attempts to factor the expression and establish inequalities to find suitable bounds.
Some participants have provided guidance on how to manipulate the expressions and set up the inequalities correctly. There is an ongoing exploration of different approaches to proving the limit, with some questioning the assumptions made in the process.
One participant raises a paradox regarding proving a limit that approaches negative infinity, leading to confusion about the validity of their proof. This highlights the complexity of limit proofs and the need for careful consideration of conditions and assumptions.
tanzl
Prove that lim (f(x) , x=a) = a4 where f(x)=x4
I think I understand the mechanics of limit proof. I just want to improve my way of presenting it because sometimes even I feel ambiguous for my own works.
For all [tex]\epsilon[/tex]>0, there exists [tex]\delta[/tex]>0 such that if 0 < |x-a| < [tex]\delta[/tex], then |f(x)-a4| < [tex]\epsilon[/tex]
I think the mechanic of the proof is I need to find delta in terms of epsilon such that it satisfies all the conditions above. (or another way round, for me, the proof more like I need to express f(x)-L where L is the limit in terms of delta so that I could make it smaller than epsilon... please correct me)
So, the first thing I need to do is to express |f(x)-a4| in terms of delta.
|f(x)-a4|
=|x^4 - a^4|
=|x-a| * |x3 + ax2 + a2x + a3|
<=|x-a| * |x3| + |ax2| + |a2x| + |a3|
My problem comes, (when it starts to sound ambiguous)
What I do is I will let |x-a| < [tex]\delta[/tex]1 where [tex]\delta[/tex]1 is a positive number such that |x3| + |ax2| + |a2x| + |a3| < P where P is a positive number.
My reason of doing this is I need to obtain a close interval for the expression |x3| + |ax2| + |a2x| + |a3| so that I can make |f(x) - L| smaller than epsilon. Therefore, I started out by letting |x-a| smaller than [tex]\delta[/tex]1 which is a arbitrary positive number. Then by algebraic manipulation, I can obtain an inequality of |x| smaller than [tex]\delta[/tex]1 +a . So when I substitute [tex]\delta[/tex]1 +a into each terms of |x3| + |ax2| + |a2x| + |a3|, I can get inequality of each terms smaller than something. To save the trouble, I let the whole expression less than P which is also an arbitrary positive number.
Since |x3| + |ax2| + |a2x| + |a3| < P
then |x-a| * |x3| + |ax2| + |a2x| + |a3| < [tex]\delta[/tex] *P
So, when I let [tex]\delta[/tex] *P = [tex]\epsilon[/tex]. (I should express delta in terms of epsilon or epsilon in terms of delta?? The first sounds more correct for me because our mission is to find a delta for any given epsilon)
Done.
Please feel free to correct me.
I'll rewrite what you've wrote thus far.
[tex]\forall \epsilon > 0, \exists \delta > 0[/tex] such that [tex]\left| x^4 - a^4 \right| < \epsilon[/tex] whenever [tex]0 < \left| x -a \right| < \delta[/tex]
From here, we need:
Factor we get:
[tex]\left| x - a \right| \left| x^3 + a^{2}x+x^{2}a+a^3 \right| < \epsilon[/tex]
Since we have that [tex]\delta > \left| x - 2 \right|[/tex], then you need to find a delta such that
[tex]\left| x - a \right| \left| x^3 + a^{2}x+x^{2}a+a^3 \right| < \left| x - a\right|*P < \delta*P < \epsilon[/tex]
Naturally, you want such that [tex]\delta = \frac{\epsilon}{P}[/tex]
Hope that helps.
|f(x)-a4|
=|x^4 - a^4|
You need parentheses, of course. But there is no reason to break up |x3+ ax2+ a2+ a3|. It's awkward and doesn't help.
Done.
You are assuming, in any case, that x is close to a, say a-1< x< a+1. x2< (a+1)2 and x3< (a+ 1)3. That should let you set an upperbound on |x3+ ax2+ a2+ a3|.
It helps a lot. Thank you.
I have a paradox here. Please tell me what is wrong.
I need to prove that limit (f(x) , x = a-) = -[tex]\infty[/tex]
f(x) = [tex]\frac{x}{(x-1)^2(x-3)}[/tex]
1st case
For all M , where M is a arbitrary large number, there exists [tex]\delta[/tex]>0 such that f(x)<M whenever 0 < a-x < [tex]\delta[/tex]
0 < a-x < [tex]\delta[/tex].
a-[tex]\delta[/tex] < x < a
Therefore x<a ...(1)
Let |x-a| < [tex]\delta[/tex]1 where [tex]\delta[/tex]1 is a positive number such that [tex]\frac{1}{(x-1)^2(x-3)}[/tex] < P where P is a positive number. ...(2)
< [tex]\frac{a}{P}[/tex] ... from (1) and (2)
Let [tex]\frac{a}{P}[/tex]=M
f(x) < M
Done.
2nd case
For all M , where M is a arbitrary large number, there exists [tex]\delta[/tex]>0 such that f(x)>M whenever 0 < a-x < [tex]\delta[/tex]
I proved this for fun at first. But, it bothers me when it became confusing that the proof contradicts itself.
As above,
Therefore x>a-[tex]\delta[/tex] ...(1)
Let |x-a| < [tex]\delta[/tex]1 where [tex]\delta[/tex]1 is a positive number such that [tex]\frac{1}{(x-1)^2(x-3)}[/tex] > P where P is a positive number. ...(2)
> [tex]\frac{a-\delta}{P}[/tex] ... from (1) and (2)
Let [tex]\frac{a-\delta}{P}[/tex]=M
f(x) > M
Done.
I derive the both cases with the same arguments but obtain opposite result. What is wrong with my proof and how valid this proof can be?
How to type limit notation by LATEX...
  • · Replies 26 ·
