Can a Voltage Multiplier and Mechanical Commutator Enhance Motor Performance?
The discussion explores the potential of using a voltage multiplier in conjunction with a mechanical commutator to enhance the performance of a DC motor. The user is interested in increasing the no-load RPM and current response of a motor characterized by a high L/R time constant and low RPM. Several circuit diagrams are presented to illustrate the proposed configurations, which involve batteries, inductors, capacitors, and diodes. The effectiveness of these configurations in achieving the desired voltage increase and performance improvement is questioned, prompting a request for feedback on the designs. The conversation centers on the feasibility of these electrical enhancements for motor operation.
kmarinas86
I saw the following video:
Lecture Series on Electronics For Analog Signal Processing I by Prof.K.Radhakrishna Rao, Department of Electrical Engineering,IIT Madras. For more details on NPTEL visit http://nptel.iitm.ac.in
Category: Education
Tags:
Voltage Multiplier
So I was wondering, is it possible that attaching a pack of batteries coupled with a motor with a mechanical commutator (for a DC electric motor) and a voltage multiplier allow me to effectively increase the voltage of the VDC output in opposite polarity provided that the system has a mechanical commutation?
Say for example I have the following:
Code:
 __-INDUCTOR+__COMMUTATOR ON STEEL SHAFT
 |__|CAP|_______|
BAT D^O    DVO  |
 |/______|CAP|_\|
Would that work?
Is the following better?
Code:
 |__|CAP|_______|
BAT D^O    DVO
 |/______|CAP|_\
Category: Education
Tags:
Voltage Multiplier
Code:
 |__|CAP|_______|
BAT D^O    DVO  |
 |/______|CAP|_\|
Would that work?
Code:
 |__|CAP|_______|
BAT D^O    DVO
 |/______|CAP|_\
What about:
Code:
 |__|CAP|       |
BAT D^O    DVO  |
 |/______|CAP|_\|
I don't follow what you are trying to do?
It's for a motor.
To describe the motor, it has a high L/R time constant and is generally high torque and low rpm. The armature (electromagnet) sits, while the rotor (magnet) interacts with the electromagnet's changing field.
In particular, I am looking to increase the no-load rpm using this system of capacitors and diodes. Also, increasing the voltage should allow the current to rise faster as well.
But to answer my question, you'll have to address what you can tell from the circuit diagrams above.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
