Calculating Doubling Time of Bacteria in Beaker
  • Thread starter Thread starter stegz
    Bacteria Time
To calculate the doubling time of bacteria in a beaker, the initial population of 2000 increased to 2500 in one hour. The growth can be modeled using the exponential growth formula, where the rate (r) must be determined first. The correct approach involves using the relationship B(t) = B_0 * 2^(t/T), where B_0 is the initial population and T is the doubling time. By substituting the known values into the equations, one can solve for T. Understanding the exponential growth concept is crucial for finding the solution.
stegz
1. Homework Statement
A beaker contained 2000 bacteira. one hour later the beaker contained 2500 bacteria. What is the doubling time of the bacteria?
2. Homework Equations
rate = (distance)/(time)
Time to double = .693/((ln(1+r))^t)
3. The Attempt at a Solution
rate = 2500/2000
My biggest problem is trying to find the rate, I used this at first, but think it is giving me the wrong answer. I know how to finish the problem, i just need help finding the rate. Thanks!
i would assume exponential growth rate here... use:
P=Ae^(rt)
A is initial quantity, P is quantity at time t, t is time of course, and r is rate
in the first part of the equation they give you enough info to solve for r, (using ln's which i assume you know how to do), now that you know r you have enough information to some for your solution. (it may not look like at first, but just think what happens after the initial population DOUBLES...)
good luck,
jared
"Rate= distance/time"? There is no "distance" here- that's not what "rate" means here!
If the bacteria double in T hours, you multiply by 2 for every "T" in the time: that is, for t hours, you multiply by 2 t/T times: B(t)= B_0 2^{t/T}. you are told that B(0)= 2000 and B(1)= 2500. That gives you two equations to solve for B_0 and T.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
