Eigenvalue of momentum for particle in a box
The discussion revolves around the eigenvalue of momentum for a particle in a one-dimensional box, focusing on the implications of the wave function and the momentum operator in quantum mechanics. Participants explore theoretical aspects, mathematical reasoning, and the interpretation of momentum distribution in this context.
  • One participant states that the wave function for a particle in a box is Asin(kx) and seeks help in finding the eigenvalue of momentum using the momentum operator.
  • Another participant argues that the wavefunctions of a particle in a box are not eigenfunctions of the momentum operator and challenges others to verify this by operating on the wavefunction.
  • Some participants mention that a given kinetic energy corresponds to two possible momentum values in one-dimensional motion, leading to an expectation of zero momentum.
  • There is a discussion about whether the momentum distribution is discrete (±sqrt(2mE)) or continuous, with references to different interpretations and examples from the web.
  • One participant asserts that the momentum operator does not exist in the context of a particle in a box due to the boundary conditions that require wavefunctions to vanish outside the box.
  • Another participant questions the existence of the Hamiltonian operator if the momentum operator does not exist, leading to further exploration of the relationship between these operators.
  • Some participants discuss the implications of defining the momentum operator under different boundary conditions, such as periodic boundaries, and how this affects the interpretation of momentum eigenvalues.
  • There is a suggestion that the Fourier transform approach might be more appropriate for practical purposes when considering large but finite potentials.
  • One participant emphasizes that the conditions of the wavefunction (ψ(0)=ψ(L)=0) are crucial to the discussion of the momentum operator's existence.
Participants express multiple competing views regarding the existence of the momentum operator and the nature of momentum distribution for a particle in a box. There is no consensus on whether the momentum distribution is discrete or continuous, and the discussion remains unresolved.
Participants highlight limitations in defining the momentum operator based on boundary conditions and the implications of considering infinite versus finite potentials. The discussion reflects varying interpretations of quantum mechanics principles without reaching a definitive conclusion.
feynmann
The wave function of "particle in a box" is Asin(kx).
Since potential energy is zero inside the box, so the Hamiltonian is just kinetic energy
In principle, I should be able to find eigenvalue of momentum using momentum operator,
but stymied in solving the equation. Can somebody help me find whereabouts I am going wrong here? Thanks.
Here's the link to Particle in a Box
http://hyperphysics.phy-astr.gsu.edu/hbase/quantum/pbox.html#c1
I didn't think that the particle in a box wavefunctions are eigenfunctions of the momentum operator. Just try it!
Operate on the wavefunction with the momentum operator, and set it equal to a constant * the wavefunction. Is it possible to solve that equation for all x?
The classical relationship between kinetic energy and momentum is
K = \frac{p^2}{2m}
In one-dimensional motion, a given value of K corresponds to two possible values of momentum.
And that's why the expectation of momentum is 0.
Hi.
This is rather old QA but I have some uneasiness to the answers of jtbell and Vanadium 50.
About momentum distribution, some people say it is discrete values of ±sqrt(2mE).
Examples in Web
http://itl.chem.ufl.edu/4412_aa/partinbox.html   (16)
http://people.ccmr.cornell.edu/~muchomas/P214/Notes/QuantumMechanics/node8.html
Other people say it is continuous and its probability amplitude is derived from Fourier transform of wave function.
Examples in Web
http://www.ecse.rpi.edu/~schubert/Course-ECSE-6968%20Quantum%20mechanics/Ch03%20Position&momentum%20space.pdf    P.21 Figure 3.2
http://www.falstad.com/qm1d/ applet
Which is the right answer? I think the latter is logical.
Regards.
As I laid out in another thread on the same topic some days ago, the momentum operator does not exist in that problem. The momentum operator is defined as the generator of a translation of the wavefunction on which it acts. However in the problem at hand, the wavefunctions have to strictly vanish outside the box. Any shift of the wavefunction will generally violate this condition whence the operator cannot exist.
Independent from this reasoning, it is possible to define the operator hbar/i d/dx, e.g. with periodic boundary conditions. The eigenvalues of the latter operator form a basis for a Fourier transform, however, they do not correspond to momentum in that example.
Hi.
Thanks DrDu
Let me ask you a question. Energy operator or Hamiltonian H is p^2/2m + V. Even if P does not exist, H which consists of P can exist?
Regards.
Yes, you are completely right. p^2 =-d^2/dx^2 is not the square of the momentum operator. That is a common problem with differential operators on a bounded interval.
Another, perhaps less artificial example, is the radial momentum, i.e. the momentum operator conjugate to the radial distance r. This operator can also shown not to exist. However its square is well defined and contributes to kinetic energy.
The classic text is John von Neumanns "Mathematical foundations of quantum mechanics".
Hi.
Concerning momentum disritibution of a particle in a box,
a. two discrete values of ±sqrt(2mE) of each 50% probability are observed.
b. continuous values whose probability is calculated from Fourier transform of wave function are observed.
c. the momentum operator does not exist in this system.
Now we have another choice c thanks to DrDu. Is there any way to fix one answer to this system?
Regards.
case a corresponds to an analysis in terms of the eigenfunction of the operator hbar/i d/dx with periodic boundary conditions which is certainly not the momentum. Hence it can be ruled out.
The choice between b and c depends on your definition of the problem. If you consider only the functions defined on the interval 0 to L (the length of the box), then c is correct.
If you consider the full range of x values, x=- infinity to x=infinity, then a is correct.
Hi, DrDu.
Thank you for your reasonable suggestions. I will restate below.
Concerning Momentum distribution of a particle in a box,
-in case the world is x(- infinity, + infinity):
b. continuous values whose probability is calculated from Fourier transform of wave function are observed.,
-in case the world is x[0,L]:
c. the momentum operator does not exist.
-No Good at all times:
Many authors have stated "a". Even W.Pauli in his Wave Mechanics (Vol. 5 of Pauli Lectures on Physics) did it.
Regards.
Hmmm ... I have a little trouble understanding this in the sense of a limit. I completely understand what you are saying if the potential well is actually infinite, however what happens when it is just really really big compared with the energy level spacing (which occurs for some real problems)? In such cases, a small shift of the wavefunction will lead to an abrupt damping of the parts that are shifted into the classically forbidden regions. I guess in such cases, the Fourier transform version (option b), would be correct?
In other words, is it correct to say that:
\lim\limits_{V\rightarrow\infty}\hat{p}
strictly speaking does not exist ... however for practical purposes the FT approach should be used, since it gives correct results (to a good approximation) in the case where V is very large but not infinite?
Hi. SpectraCat
If the world is limited to x[0,L], it is meaningless to say anything about potential V(x) where x does NOT exist. So I think case c actually has nothing to do with potential V, instead the given conditions ψ(0)=ψ(L)=0 play role.
Regards.
  • · Replies 75 ·
  • · Replies 41 ·
  • · Replies 60 ·
  • · Replies 24 ·
  • · Replies 41 ·
11K
