Solve Process Engineering ODE without Laplace Transforms | ODE Help
  • Thread starter Thread starter missmaria
    Ode
missmaria
So this question pertains to some process engineering homework i have, which is basically the following:
I have an ODE that has the form: \frac{dh^{p}}{dt}+h^{p}+\int h^{p}=F^{p}{t}
where F^{p}{t} is the unit ramp function (i.e. F^{p}{t}=0 when t<0, and is equal to t when F^{p}\geq0
So my question is how do i solve this ODE without using Laplace transforms?? Can there even be an integral in such an ODE??
Thanks in advance, i appreciate your help
We can remove the integral sign by differentiating the equation with respect to t
h" + h' + h = F'(t)
This is a nonhomegeneous linear DE with constant coefficients which can be solved quite easily without using the Laplace transform.
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
