Will Dropped & Shot Bullets Hit Ground at Same Time?
  • Thread starter Thread starter Charlie G
    Ground Time
If a bullet is dropped from the same height and at the same time as one fired horizontally, they will hit the ground simultaneously in a vacuum without air resistance. However, air resistance affects the bullet's trajectory, causing it to experience aerodynamic lift, which can alter its rate of descent. The discussion references classic physics experiments, like the "shoot the monkey" demonstration, which illustrate that projectiles and dropped objects fall at the same rate in ideal conditions. Overall, while textbook physics supports the idea of simultaneous impact, real-world factors like air resistance complicate the outcome. Understanding these principles is essential for accurate predictions in projectile motion.
Charlie G
Pretty simple question that I was curious about earlier today. If I were to drop a bullet from the same height and at the same time as my friend shot the bullet from a gun, would they hit the ground at the same time?
I think that they would considering the bullets frame of reference it is at rest. Though I've come to hasty conclusions before only to have a small factor completely prove me wrong, so I just wanted to ask you guys at the forums:smile:
Depends which direction you fired it !
In 'school textbook physics' without air resistance then if you fire a bullet horizontally and drop a bullet from the same height at the same time then they will hit the ground together.
Yeah, air really messes it up. Since all bullets other than wadcutters have bevelled or rounded leading edges, there is some aerodynamic lift resultant of their forward speed. That decreases the rate of drop.
This reminds me of the famous "shoot the monkey" experiments done in introductory physics classes. Here's one with a crossbow..
In my younger days, I remember seeing it done with a cannon. These are pretty convincing demonstrations that launched projectiles fall at the same rates as dropped objects.
Thx for the replies. The shoot the monky video was pretty cool:smile:
Thread 'Gauss' law seems to imply instantaneous electric field'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
