Calculating the Empirical Formula of a Material | 1.235g of C, O, and H
  • Thread starter Thread starter transgalactic
    Formula
To determine the empirical formula of a material weighing 1.235 grams, composed of carbon, oxygen, and hydrogen, combustion yields 3.425 grams of CO2 and 0.971 grams of H2O. The discussion emphasizes the importance of balancing both atoms and mass, requiring calculations of moles for CO2 and H2O to derive the amounts of carbon and hydrogen present. Oxygen's contribution is more complex, as it originates from both the material and the combustion process. Participants suggest using algebra to convert decimal mole values into whole number coefficients for the empirical formula. The process involves careful consideration of the relationships between the reactants and products formed during combustion.
transgalactic
a matirial which weighs 1.235gram
made of carbon oxigen and hydrogen
and this material burned in oxigen
which gives 3.425 gram of CO_2
and 0.971 of H_2O ??
what is the ampiric formula of the material
1258 posts and you still don't know that you have to try by yourself before asking for help?
Hi transgalactic! :smile:
What equations do you think are involved, and what constants do you need to know? :wink:
This one was reasonably difficult, but I found an answer. The trick is to account for both moles formula balance AND mass balance. (Or I should say, atoms balance AND mass balance). Initially, you have variables for the subscripts in the unknown C-H-O compound, and the way I proceeded, a coefficient variable for the reactant oxygen molecule and a coefficient 1 for the unknown compound. Like I say, I came up with what I believe is a very reasonable empirical formula result. I'd like to plainly state the result here, now, but doing so might not be acceptable at this state of progress on the forum.
i have 0.077824106 moles of CO_2
and 0.05389869 moles of H_2O
what to do next??
it not a whole numbers
and i don't know how to build balancing equations for this
Well, so you have been thinking about and studying this exercise some more. Good.
One of those values looks familar; the other I do not remember. I solved the problem on my own several days ago.
what to do next??
See my last post on this topic. At first, you do not yet know the actual coefficients for the reactant compounds.
The coefficients are unknow to start with, just as the subscripts for the atoms in the unknown compound. You need basic algebra-arithmetic skills. The decision on which final WHOLE numbers to find will come as one of your last steps. I initially found nonwhole values for one or more subscripts in the atoms of the compound also. The process was finished by finding a whole number factor which would keep all subscripts as extremely close to whole OR whole; and just good judgement.
ok
i have to find coefficient for C O H
C=x
O=y
H=z
x+0=0.077824106
y+2=2*0.077824106+0.05389869
z+0=2*0.05389869
how to get whole cofficients from this decimal numbers
hint:
can you calculate the number of moles of CO2 you obtain?! If the products are CO2 and H2O only, then all the Carbon from the initial material have gone into CO2.
so, if you have x mol of CO2 formed, then you should have had x mol of Carbon in the initial substance.
Using this same logic you can find out for Hydrogen.
but for Oxygen it is going to be a little bit tricky since the oxygen in the product comes from both the initial material and the oxygen gas supplied. you have find an alternative path!
14K
13K
