Master+Doctoral at the same Uni save my time?
  • Thread starter Thread starter tanpi
    Time Uni
The discussion revolves around the considerations of applying for a Master's program followed by a Doctoral program at a Canadian university as an international student. Key points include the likelihood of acceptance, where some schools allow direct admission to either Master's or Ph.D. programs, but exceptional candidates are typically needed for direct Ph.D. admission. It is noted that completing a Master's at the same university may facilitate a smoother transition to a Ph.D., potentially reducing completion time to 4-5 years if the research is continuous. Financial support options such as Research Assistantships (RA) and Teaching Assistantships (TA) are generally available for graduate students, with Ph.D. students often receiving more funding. Applicants can usually apply for both programs simultaneously, but it's advised to verify specific school policies regarding application processes and fees. Overall, the discussion emphasizes the importance of checking individual university requirements and policies.
tanpi
As a result from my previous post:
https://www.physicsforums.com/showthread.php?t=306199
I am wondering that if instead of applying into the Doctoral Program, I choose to repeat another Master Degree in one of the Canadian University and continue on the Doctoral Program at the same University. As an international student, here's the questions:
1. Will I be more likely to be accepted for admisssion? and during admission do I have a choice of specifying that I would like to do a Master Continuing on Doctoral?
2. Will I save sometimes in doing Master/Doctoral at the same University(completion in 4-5 years)?
3. will I be eligible for the RA/TAship or at least some partial scholarship to help with the tuition fee during my Doctoral Program(after completing Master there)?
4. During application am I allowed to apply for both program (Master/Doctoral) to improve my chance? or I have to apply twice and pay admission fee twice as well?
Thank you guys
As usual, you have to check with the specific schools that you're interested in as I'm sure the policies vary on this kind of thing. In all the programs that I'm familiar with, if you're applying straight from undergrad, you are automatically placed in a master's program. Then, based on your performance in the first year and the recommendation of your supervisory committee, you may have the option of transferring directly into a Ph.D. program. Otherwise you complete the master's degree and then apply directly for a Ph.D. program.
1. I believe some schools will allow you to apply directly to either the M.Sc. or Ph.D. programs, but you have to be an exceptional candidate to be offered direct admission into the Ph.D. program. Again, check with the particular programs you're interested in.
2. It's difficult to say. If your Ph.D. becomes an extension of your M.Sc. work, you don't have as much of a learning curve to climb as if you start a different project and therefore you have the potential to finish sooner. The same would apply regardless of whether or not you go to a different school.
3. In Canada, most graduate students are financially supported in one way or another. Ph.D. students may get slightly more money.
4. I don't think it makes a difference - but again check with the specific school. I believe in general applicants seeking direct admission to a Ph.D. program are automatically considered for a master's program.
Thank you Choppy, your suggestion is very helpful. It really helps confirming my understanding of the academic system over there. I'm sure that I don't have to post another topic related to admission now. However, the next time I post, might be relating to the research area. Thank you.
Cheers :smile:
guys i am currently studying in computer science engineering [1st yr]. i was intrested in physics when i was in high school. due to some circumstances i chose computer science engineering degree. so i want to incoporate computer science engineering with physics and i came across computational physics. i am intrested studying it but i dont know where to start. can you guys reccomend me some yt channels or some free courses or some other way to learn the computational physics.
I'm going to make this one quick since I have little time. Background: Throughout my life I have always done good in Math. I almost always received 90%+, and received easily upwards of 95% when I took normal-level HS Math courses. When I took Grade 9 "De-Streamed" Math (All students must take "De-Streamed" in Canada), I initially had 98% until I got very sick and my mark had dropped to 95%. The Physics teachers and Math teachers talked about me as if I were some sort of genius. Then, an...
I am currently in the second (and final) year of my MS in Physics. I've just started my research, which focuses on identifying Dark Matter through Beyond the Standard Model (BSM) extensions. My supervisor has directed me to learn model building using FeynRules and subsequent calculations via MadGraph or other simulators. I've successfully built models for QED and QCD, and I am now working on Weak Interactions, Electroweak theory, and symmetry breaking. My immediate goal for the next few...
