Energy of Fan Blade: Calculating Speed and Strength
  • Thread starter Thread starter Colin De Bruy
    Energy Fan
The fan, designed by Universal Hovercraft for a children's hovercraft, is powered by a 5hp petrol motor with a maximum RPM of 3000. At this RPM, the tip of the fan can reach speeds of 339 km/h (210 mph), while the inner root achieves 169 km/h (105 mph). The discussion centers on calculating the energy of a 200-gram pine blade if it were to detach at these high speeds. The inquiry references the concept of rotational energy for further understanding. Energy calculations are crucial for assessing safety and performance in hovercraft design.
Colin De Bruy
Thanks to all who posted. The fan was built by Universal Hovercraft it's purpose built for a small hovercraft designed for kids to ride on. The fan is driven by a 5hp petrol motor which has a top rpm of 3000 rpm. I doubt the engine will get to this rpm with the fan attached but at 3000rpm the tip of the fan is doing 339km per hour or 210 mph and the inner root of the blade is doing 169km or 105mph. So does anyone know how much energy a 200gram pine blade has if it were to break off at this speed? Many thanks Colin
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Calculate minimum RPM to self-balance a CMG on two legs'
Here is a photo of a rough drawing of my apparatus that I have built many times and works. I would like to have a formula to give me the RPM necessary for the gyroscope to balance itself on the two legs (screws). I asked Claude to give me a formula and it gave me the following: Let me calculate the required RPM foreffective stabilization. I'll use the principles of gyroscopicprecession and the moment of inertia. First, let's calculate the keyparameters: 1. Moment of inertia of...
