Can someone explain angular power spectrum
The angular power spectrum is derived from the cosmic microwave background (CMB) radiation by applying a spherical harmonic transform, similar to a Fourier transform but suited for spherical surfaces. This transform decomposes the CMB map into oscillations characterized by indices "l" and "m," where "l" indicates the number of oscillations and "m" denotes their directional variations. The power spectrum is constructed by averaging the coefficients of these oscillations, resulting in a function that reveals the dynamics of the universe from inflation to the present. The plot typically displays the power spectrum modified by a factor of l(l+1)/2π to facilitate interpretation, as inflation predicts a nearly constant primordial power spectrum. Features in the spectrum, such as the damping tail and the ratio of even to odd peaks, provide insights into the interactions between normal and dark matter during the universe's evolution.
hadoque
Hi
I'm trying to get my head around this plot of the cosmic microwave background radiation.
http://www.astro.ucla.edu/~wright/CMB-LCDM-w-WMAP.gif
I've been searching all around to find out what exactly a angular power spectrum is. I know what an ordinary power spectrum is.
I'm a second year university physics student, haven't read any cosmology.
Thanks for any help
Space news on Phys.org
Note: Gah, I give up on the latex. My Latex code is right, but it's still showing up as an error on my machine. If you don't see it, sorry, but you can check the link at the bottom for some more detail.
Okay, so what is done is we take the map of the CMB sky, and perform a spherical harmonic transform on it. A spherical harmonic transform is basically the same general concept as a Fourier transform, but the spherical harmonics are mutually orthogonal on the surface of a sphere, like so:
f(\theta, \phi) = \sum_{lm}a_{lm}Y(\theta, \phi)_{l}^{m}
Here the "l" index denotes the number of oscillations, and the "m" index is a way of encoding the direction of oscillation on the sphere, and varies from "-l" to "l". For example, l=0 is zero oscillation: this is the monopole that sets the overall scale. l=1 is a dipole: one full oscillation over the sphere, and there are three possible directions (x, y, and z). Go to higher and higher l values, and you get more (and therefore smaller) oscillations and more possible directions for those oscillations. The way they are typically written, the spherical harmonic functions Y(\theta, \phi)_{l}^{m} are complex functions, and the coefficients are therefore complex. This is a minor issue, though. In order to build the power spectrum, we average over directions. This is done as follows:
C_l = \frac{1}{2l+1}\sum_{m=-l}^l a_{lm}a^*_{lm}
Finally, in building that plot, you may notice that the vertical axis is not C_l, but is instead C_l l(l+1)/2\pi. It turns out if we had a power spectrum that was uniform in a logarithmic interval in l, then multiplying said function by l(l+1)/2\pi would give us a constant. Thus this multiplication allows us to interpret the function more easily, because inflation predicts that the primordial power spectrum, the one initially generated by inflation, would be nearly a constant in this space.
If inflation is true, then, all of the features you see in a power spectrum written as above that deviate from a constant stem from the dynamics of the universe between inflation and the emission of the big bang (plus some very slight modification between us and the CMB). For example, the long damping tail at high l stems from the fact that the surface of emission of the CMB is not instantaneous: the phase transition from a plasma to a gas happened over time, and the resultant blurring of the signal damps the small-scale fluctuations. There's also the ratio between the even and odd peaks of the power spectrum. This comes about because of the differences in the physics between normal matter and dark matter: dark matter just falls into potential wells, while normal matter bounces. The failure of dark matter to bounce causes a reduction of the even-numbered peaks relative to normal matter.
Anyway, if you want an in-depth description of the whole process, take a look at Max Tegmark's page:
http://space.mit.edu/home/tegmark/cmb/pipeline.html
Likes DoobleD
Thanks a lot for that lengthy explanation. I can read the latex-code by holding the cursor over the red text, so that's no problem.
Thanks again.
/Johan
https://en.wikipedia.org/wiki/Recombination_(cosmology) Was a matter density right after the decoupling low enough to consider the vacuum as the actual vacuum, and not the medium through which the light propagates with the speed lower than ##({\epsilon_0\mu_0})^{-1/2}##? I'm asking this in context of the calculation of the observable universe radius, where the time integral of the inverse of the scale factor is multiplied by the constant speed of light ##c##.
The formal paper is here. The Rutgers University news has published a story about an image being closely examined at their New Brunswick campus. Here is an excerpt: Computer modeling of the gravitational lens by Keeton and Eid showed that the four visible foreground galaxies causing the gravitational bending couldn’t explain the details of the five-image pattern. Only with the addition of a large, invisible mass, in this case, a dark matter halo, could the model match the observations...
Hi, I’m pretty new to cosmology and I’m trying to get my head around the Big Bang and the potential infinite extent of the universe as a whole. There’s lots of misleading info out there but this forum and a few others have helped me and I just wanted to check I have the right idea. The Big Bang was the creation of space and time. At this instant t=0 space was infinite in size but the scale factor was zero. I’m picturing it (hopefully correctly) like an excel spreadsheet with infinite...
