Physics of Pointed vs. Rounded Lightning Rods
  • Context: Undergrad
  • Thread starter Thread starter brewcrew975
    Lightning Physics
The discussion centers around the physics of pointed versus rounded lightning rods, exploring the mechanisms by which pointed rods may enhance the likelihood of lightning strikes due to their electric field properties. Participants delve into theoretical explanations and implications of charge distribution and electric fields in different geometries.
  • Some participants propose that pointed lightning rods concentrate electric fields, which intensifies the field and facilitates the ionization of air, leading to lightning strikes.
  • One participant explains that the geometry of a sharp object in an electric field causes "field enhancement," resulting in a significant charge accumulation at the point.
  • Another participant mentions that with enhanced fields and charge accumulation, "field emission" may occur, allowing charge carriers to tunnel through barriers and potentially ionize surrounding air.
  • There is a question raised about the behavior of irregular conductors in uniform electric fields, specifically regarding charge distribution and electric field characteristics within and around the conductor.
  • A later reply asserts that the electric field inside a conductor is zero and that the potential remains constant, but acknowledges that charge distribution depends on the conductor's geometry.
Participants express various viewpoints on the mechanisms at play with pointed versus rounded rods, and while some concepts are discussed, there is no clear consensus on the implications or the specifics of charge distribution in irregular conductors.
Limitations include the dependence on specific geometrical configurations and the unresolved nature of how irregular conductors behave in uniform electric fields.
This discussion may be of interest to those studying electromagnetism, lightning phenomena, or the physics of charge distribution in conductors.
brewcrew975
What are the physics behind using a pointed lightning rod as opposed to a rounded one. I believe it has something to do with the electric field being concentrated to a point intensifying the field but can someone thoroughly explain it. Thanks!
Science news on Phys.org
The point of the point (:blushing:) is to ionize the air and initiate a breakdown.
The charge is more concentrated round the point and this sets up an intense electrical field which breaks down the insulation of the air.This results in charged particles moving between the point and the cloud this achieving some neutralisation.
It turns out that if one were to solve the field equations (i.e. Poisson's equation) whereby you put a sharp, pointing metal in, say, a uniform electric field, something called "field enhancement" occurs in the region of the sharp, pointy object. This is purely classical E&M solution out of Maxwell equation. So such sharp objects causes an enhancement of the electric field at its location. So the geometry of the object within such field is the cause.
The resulting effect here is that there's a huge charge accumulation in that region. With the enhanced field, and the large charge accumulation, a phenomenon called "field emission" can occur (or at least, has a higher probability of occurring). This is where the charge carriers can quantum mechanically tunnel through the surface barrier. When this occurs, a number of possible mechanism can occur that can lead to the ionization of the surrounding air, and that can lead ultimately to an air breakdown/lightning/etc.
Zz.
Hey i am interested in something here
what hapens if we place an irregular conductor in a uniform electric fields! Actualy what's the distribution of charges at the ends and at the middle and every where, what's the net electric field inside the conductor, and what's and how is the potential over the surface of that conductor?
The electric field inside the conductor will be zero, likewise the potential will be a constant zero. The charge distribution would depend on the geometry of the conductor.
  • · Replies 26 ·
