Changing the subject of a formula
  • Thread starter Thread starter chuckienz
    Formula
To make X the subject of the formula XA + BA = B, one must reverse the operations applied to X. First, subtract BA from both sides of the equation to isolate the term involving X. Next, divide both sides by A or multiply by A^-1 to solve for X. This process involves reversing the order of operations and ensuring that any changes made to one side of the equation are also applied to the other side. Following these steps will yield the desired expression for X.
chuckienz
Ok, this most likely will be a silly question but I am having trouble trying to make X the subject of the formula XA +BA = B
im hoping someone is able to enlighten me
Thanks
Mathematics news on Phys.org
chuckienz said:
make X the subject
What do you mean by "subject"?
That British for what we Americans would call "solve the equation for x".
chuckienz, you solve an equation, or make x the subject of the equation, by "reversing" what has been done to x. Here, the equation is XA+ BA= B.
If I were given a value for A and asked to evaluate the left side, I would do two things: first multiply by A, second add BA. Here, you want to do the opposite. The opposite of "multiply by A" is "divide by A" or, same thing, "mutiply by A-1". The opposite of "add BA" is "subtract BA". Also, you because you are "reversing" everything you must also reverse the order. And, of course, anything you do to the left side of the equation, you must do to the right side.
So:
1) Subtract BA from both sides of the equation.
2) Multiply both sides of the equation by A-1.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
