Question in U.S. Diesel Emission Standards
  • Thread starter Thread starter Su Solberg
    Diesel Emission
The discussion clarifies that "Tier" and "EPA" emissions standards are synonymous in the U.S., while California's standards, set by CARB, may differ in application and implementation. The introduction dates for on-road and off-road standards vary, affecting compliance timelines and calculation methods. Although the allowable pollutant concentrations are broadly similar, the specifics of each standard can differ significantly based on the application. The conversation highlights the ongoing development efforts to meet Tier 4 emissions levels in industrial applications, contrasting with the automotive sector's earlier compliance. Understanding these distinctions is crucial for navigating U.S. diesel emission regulations effectively.
Su Solberg
I wonder is what are the legal and application area difference between "Tier","EPA" and "California" Emission Standard in U.S (I am not asking the allowable emission levels).
Also, Is there any difference in on-road and off-road standads(again, I am not asking the emission levels)?
Thanks for your kind help in advence.
The EPA set emissions levels by "Tier" (e.g. "this Tier 4 level the EPA have set is a right bastard!"). The two are synonymous. Don't know about CARB, I'll do some reading at work and let you know later in the week.
On and off-road standards (for EPA and EU) are broadly the same in terms of allowable pollutant concentrations, but do differ in introduction dates, and (depending on application) the way the figures are calculated. That is to say, we (industrial) are currently developing to meet Tier 4 emissions levels but the automotive guys did this a while back.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
