How can gradient be zero if its a normal vector?
The discussion centers on the concept of the gradient as a normal vector to equipotential surfaces defined by the equation φ(x,y,z) = 0. It raises the question of how the gradient can be zero for certain surfaces, as this would imply the absence of a normal vector, which seems contradictory. The conversation highlights that while the gradient is typically non-zero for most surfaces, there are instances where grad φ equals zero, particularly in constant potential fields. This leads to the inquiry about the uniqueness of equipotential surfaces when φ is constant, such as φ(x,y,z) = 2. The exploration reveals complexities in understanding gradients and normal vectors in various contexts.
aaryan0077
Physical interpretation of gradient says that its a vector normal to equipotential (or level) surface \phi(x,y,z) = 0
but what about other surfaces, say the surface which are not equipotential?
This is my first question.
ok, now
as grad \phi is a vector normal to surface it can't be 0. Because that would mean that surface have no normal vector, or say a normal vector of indeterminate direction (as 0 vector is of indeterminate direction). how can it be possible that a surface has no normal vector, more specifically a 0 vector as its normal vector?
But I have seen many examples in which grad \phi is 0.
So doesn't that contradicts the assumption that grad \phi is a normal vector?
Mathematics news on Phys.org
Equipotential surfaces are defined by the eqution:
\phi(x,y,z) = C (C is constant)
But consider the contant potential field ,say \phi(x,y,z) = 2,can you find a unique equipotential surface for it?
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
