rasp said:
Space has no characteristic that I am aware of. It doesn't "look" like anything to observers. It has no primary meaning but is defined only secondarily as distance in relationship to the objects it separates.
I agree. At least in cosmology we can assume that space has no physical material existence, it is not a substance like rubber.
The balloon analogy is not a mechanical model but a device to help people visualize. Think only of the surface of the balloon---all existence concentrated on the 2D surface. No rubber.
rasp said:
Space has what type of characteristics that stretches or expands with time? How are you defining space, that it might stretch as if it were actually the same as its balloon analogy?
You answered your own question. There is no physically existing space. There is, however, geometry. Once can make measurements. One can measure the angles of a triangle. there is an idea of a straight line. Of distance. As you indicated, geometry is primary. Space is
"only secondary", as you said.
rasp said:
Can we call this backdrop the balloon? Well, then what of the balloon itself? Is it moving? If so, what is moving?...
A common perspective on the universe is to consider the backdrop to be the CMB---the microwave background. Light left over from ancient matter which was approximately uniformly distributed (before it began to curdle and clump) and of an approximately uniform temperature.
One can tell one is moving relative Background if there is a doppler hotspot ahead of one, and one can measure the speed by the dopplershift. One has an idea of rest with respect to Background.
It's convenient. They use it to analyze data. It is convenient to think of the background as not moving. then each of the galaxies has some proper motion relative background which can in many cases be estimated. These proper motions are normally rather slow. Not part of the expansion pattern.
rasp said:
This thread has evolved far beyond me, can I interject back to my original question? I understand that the galaxies are not moving per se at velocities greater than c, but are only in relation to each other as "the "backdrop of dynamic geometry" expands. Can we call this backdrop the balloon?
It is convenient to think of the backdrop as not moving. It is a handy anchor point, a reference for all other motions. I would prefer not to call it "the balloon" because the balloon is just a visualization aid.
I guess a communication problem might be that I believe that geometry exists (not as a substance but) as a pragmatic reality. And you might not believe this. It would make it hard to communicate if that is true. Let me explain how I think that geometry exists.
GR equates the gravitational field to the geometry. The gravitational field is
nothing else but the geometry. Geometry is as real as gravity. And it as real as the pragmatic fact that I can measure angles and distances. Moreover geometry is not naturally Euclidean. It evolves. At any given place we have no right to expect it to be static or flat. GR explains why in certain circumstances it will be approximately flat. Why in others it will be expanding or contracting according to some pattern.
Some other branch of physics may explain why the gravitational field (i.e. geometry) exists. Here we just take as given that it exists and that it evolves according to the main GR equation.
So distances between stationary observers (at rest w.r.t. background) increase according to some pattern (Hubble law) and this is not surprising.
And space is not a substance, neither is geometry a substance.
You might enjoy reading Rovelli's parable of the whale. I will see if I can find a link.
This links gets an early draft the whole book,
http://www.cpt.univ-mrs.fr/~rovelli/book.pdf
Look at section 1.1.3 "The physical meaning of general relativity," page 7.
And also more elaboration, with quotes from Einstein and others, in section 2.3.2 "The disappearance of spacetime". On pages 52 and 53.
