Absorbance of UV light by glass
The discussion focuses on investigating the absorbance of UV light by glass of varying thickness, with an emphasis on theoretical calculations rather than practical experimentation due to time constraints. The Beer-Lambert Law is highlighted as a key principle for understanding light absorption through a medium, which includes concepts like the absorption coefficient and extinction coefficient. Participants suggest that absorbance will likely plateau at a certain thickness, indicating that glass can still allow UV light to cause sunburn. There is uncertainty regarding the exact values for UV absorption coefficients in glass, particularly for standard soda lime glass. Overall, the conversation seeks guidance on how to establish a theoretical framework for the assignment without conducting physical experiments.
N0b0dy
Hi, I'm doing an investigation into the absorbance of UV light by glass of varying thickness (constant density and standard type of glass) for an assigment. However, we're not actually supposed to carry out the investigation due to time constraints, so we're meant to make up the numbers ourselves. This would be easy if I was doing a topic such as projectile motion. However, in this case I have literally no idea what figures I should include. Could anyone please help get me started by suggesting some increments of glass thickness that would demonstrate a particular relationship? I assume the graph (absorbance % against glass thickness) would plateau off at a certain point because I've heard many people say that you can still be sunburnt no matter what kind of glass it is.
Science news on Phys.org
Since this is homework, rather than give you the answer, I'll just give you a few hints:
The Beer-Lambert Law, or Beer's Law, or a few other permutations deals with absorption of light through a medium as the light passes through said medium:
http://en.wikipedia.org/wiki/Beer-Lambert_law
You'll note that one of the formulations involves the absorption coefficient \alpha which is elaborated on further down in the article. Part of that elaboration is the extinction coefficient \kappa.
The extinction coefficient of some glasses (including plain-jane soda lime glass) is given here (no idea whether or not they're right, however):
http://www.colostate.edu/orgs/SEAL/research/IAM/iamv2/manual.txt
Keep in mind that this is probably for a visible colour, and when dealing with real glass and UV light, the approximation given for absorption coefficient is probably going to differ a fair bit from the 'real' value (which I can't easily find anywhere on the internet)
EDIT: Disclaimer, I am not an optics guy.
So there's not really any practical way of working this out unless I actually carry through with the experiment? This is high school standard so I assume I don't need to go into such great detail. Could anyone provide me with a hint as to when the absorbance plateaus off which I can base my 'results' on?
I would like to use a pentaprism with some amount of magnification. The pentaprism will be used to reflect a real image at 90 degrees angle but I also want the reflected image to appear larger. The distance between the prism and the real image is about 70cm. The pentaprism has two reflecting sides (surfaces) with mirrored coating and two refracting sides. I understand that one of the four sides needs to be curved (spherical curvature) to achieve the magnification effect. But which of the...
