Why the point of x + iy would be (x, y) ?
  • Thread starter Thread starter I_am_no1
    Point
Argand diagrams represent complex numbers in a two-dimensional plane, where the x-axis denotes real parts and the y-axis denotes imaginary parts. A complex number in standard form, a + ib, corresponds to the point (a, b) on this diagram. Real numbers are represented as points on the x-axis, specifically as (a, 0). The operations defined for ordered pairs in R² apply similarly to complex numbers, allowing for addition and multiplication in this context. Thus, the relationship between complex numbers and their representation on Argand diagrams is fundamentally about notation and coordinate systems.
I_am_no1
What argand diagrams really are ? Is there any difference between graph and argand diagram?
For complex number i is a sign that is count as \sqrt[]{-1}
Then why the point for a + ib would be (a, b) in argand diagram ?
That means, x = real part = a
y = imaginary part = b
so if i want to find out real numbers point than it would be on x-axis alone, right? [would the point for 'a' (a € Real number) would be (a, 0) in argand diagram ?]
Mathematics news on Phys.org
I just think of it as a matter of notation. To develop the ordered pairs of real numbers, define an addition and multiplication on R^2:
(a,b) + (x,y) = (a+x, b+y)
(a,b) * (x,y) = (ax-by, bx+ay)
According to this definition, (0,1)*(0,1) = (-1,0) and is then denoted i^2 by construction. Rewriting (a,b) as a+bi and calling the plane C rather than R^2, the operations hold:
(a+bi) + (x+yi) = (a+x) + (b+y)i
(a+bi) * (x+yi) = (ax-by) + (ay+bx)i
And if b=0 in a+bi then a+0i = a which is the real part of the complex number and is a real number, also known as (a,0) in C.
Hi I_am_no1! :smile:
(have a square-root: √ :wink:)
Not really …
a complex number can be written in standard form as a + ib, or in polar form as re, and they correspond to cartesian and polar coordinates on an argand diagram.
Yes, the x-axis is all the real numbers, and the y-axis is all the imaginary numbers …
for that reason, they're also called the real axis and the imaginary axis. :smile:
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
