Validate Peano Arithmetic Approach
snipez90
Show that the natural numbers satisfy commutativity of multiplication and distributivity of multiplication over addition.
I'm wondering if there is any potential circularity in this reasoning. I proved distributivity over addition first by say, fixing n, m and showing that M = {p in naturals | (n+m)p = np + mp} is equal to the set of natural numbers.
Then I used distributivity in the final step of my commutativity proof where the inductive hypothesis was mk = km and the inductive step m(k+1) = mk + m = km + m = k(m+1) (literally the last equality follows from distributivity).
This seems valid, but I know that distributivity is usually stated with both (n+m)p = np + mp and p(n+m) = pn + pm. Typically this follows from commutativity, but would this still follow even if I used the distributive law in my commutativity proof?
I suppose it would be fine to have a sequence like:
- Show left distributivity: (n+m)p = np + mp
- Show commutativity, only using left distributivity
- Right distributivity follows
However, it looks like you are using right distributivity in the proof of commutativity. If you had in the final step: mk + m = (k + 1)m it would be fine, as you have just proven that to be true (assuming you know that 1k = k, and fun stuff like that).
By the way, note that
m(k + 1) = k(m + 1)
is not true (m = 1, k = 2 is a counter example) -- you meant: km + m = (k + 1)m ?[edit]On closer inspection, I think you need both right and left distributivity, if you set it up this way. However, my guess is that right distributivity is an almost-copy of the proof of left distributivity [/edit]
Sorry that was a huge typo. I mean m(k+1) = mk + m = km + m = (k+1)m, which should be permissible since I proved that 1 is the multiplicative identity for the base case of the same commutativity proof. I'll try to set up right distributivity and then prove commutativity I guess.
*EDIT* I guess the smartest route to take would be left distributivity -> multiplicative identity -> right distributivity -> commutativity (use multiplicative identity for base case).
