Understanding Polarization: Reflection and Refraction at a Water-Glass Interface
  • Thread starter Thread starter Supertramp19
    Polarization
The discussion focuses on the behavior of unpolarized light at the water-glass interface, specifically analyzing the amplitude and intensity of reflected beams at various angles of incidence. It highlights that total linear polarization occurs at a specific angle, known as Brewster's angle, which can be calculated for the water-glass scenario. The interaction of light as it transitions from water to glass is also examined, noting that the reflected light from the glass is completely linearly polarized. Additionally, a sketch is suggested to visualize the arrangement of light beams and polarization directions at the interfaces. Understanding these principles is crucial for applications in optics and photonics.
Supertramp19
A beam of unpolarized light (III=IP= I0 and EII= EP= E0) is incident from air on a plane interface of water (n = 1.33).
(a) Under the incident angle of θi = 0°, 30°, and 70°, what is the amplitude (E) and intensity (I) of the reflected beam (relative to the values E0 and I0 of the incident beam) for the two E parts of the light, polarized II and to the plane of incidence?
(b) At what particular angle of incidence will you achieve total linear polarization for the reflected light?
(c) The light refracted into the water in (b) is intercepted by the top flat surface of a block of glass (n = 1.6), which is immersed in the water. The light reflected from the glass back into the water is completely linearly polarized. What is the angle between the glass and water surface?
(d) Plot both particular cases (b) and (c) together in a sketch of the plane of incidence showing the directions of the incident, reflected, and transmitted light beams, and also the polarization direction of the reflected light. Include in your sketch the arrangement ofthe glass block relative to the
water surface. You need not consider any reflections at the bottom of the glass block.
Note: II means parallel and P means perpendicular.
I know it's a lot to ask. Thanks for any help/hints in advance!
Show work?
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
